Question about Nintendo 64 Console
N64 red light turns on but no sound or video onscreen
I had all the AV in correctly and a game in. I turned on and the little red light came on but nothing on the screen and no sound
  • weasel699
    weasel699 Jan 01, 2013
    so i found my brother's n65 and it wont run either..same thing power light comes on but not pic or sound i even tryed hooking directly up to the tv and vcr since i was useing one of those boxes with the multi av hookups on it and still nothing. even tryed the Gc's av cord and nothing..the cord works because it runs the Gc
  • Nintendo Master
  • 427 Answers
Nintendo 64 - Blank Screen Troubleshooting
Quick Tip: If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
  1. Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
  2. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  3. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Lightinstructions.
  4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
  5. Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Posted on Nov 15, 2016
  • 18 Answers
SOURCE: N64 light comes on, but nothing comes on screen
Make sure that the game you are trying to play is free of dust and other obstructions.  I know that the label on the back of the game says that you should never blow on the edge connector, but it doesn't harm the game. (Trust me I've been cleaning the connectors for years now, and it hasn't been damaged.  After you throughly rid the game of dust, do the same with the edge connector on the N64.  Simply hold the opening open and blow the dust out.  This should work.   Please give feedback!! Hope this helps!!
Posted on Apr 16, 2009
SOURCE: N64 will not play on new TV and Stereo Reciever
Ok well, I don't guarantee this will work but its worth giving a shot. You know the controls like V1 2,3,4,and 5? That might be a clue because all that stuff works the stuff that's plugged into the back of the TV. They have extra cable outlets or whatever you'd like to call them in the back of the TV. So plug the n64 into the back of the TV. Then it should work someway. You might be able to figure out it from there if it still doesn't work. So don't plug it into the cable box or VCR anymore. Hope that helps.
Let me know if it works after that.
P.S. I have a n64 too, and I just got a new HDTV also. I tried to see if my n64 works on it but it doesn't so I think I might do the samething that I was just explaining
Posted on Feb 03, 2009
SOURCE: N64 turns on but nothing shows up on the TV
I have the same problem and from what I've read elsewhere on the net, it seems to be easily amendable by one of two solutions.
- You can re-tune a channel on your TV (not one of the main ones) and it will find the frequency for your N64 to run on
- If you had a gamecube the yellow, red and white output cables that came with that are (apparently) compatible with both the N64 and SNES and that way you wont have to tune your TV.
Unfortunately for me, I did not have a GC and my TV will not re-tune due to the button on the controller not working! Good luck.
Posted on Feb 12, 2009
  • 13 Answers
SOURCE: hooking up my n64, sound works, no video
make sure the yellow video wire is plugged into the correct port
Posted on Nov 02, 2009
  • 12 Answers
SOURCE: My N64 does not play games... red ight... help plz...
your chords are not hook up.
Posted on Dec 20, 2009
When turning on my N64, the power light turns on and I have a standard AV cable hooked up, but the video will not come through on the TV.
Step 1:
So you've eliminated the possibility of bad cables. Now you need to eliminate the TV and the Nintendo 64 itself.
Step 2:
For the TV, you can try another TV or make sure that you have the TV set on the right input.
Step 3:
If you can't make it work on an additional TV and you have made absolutely sure that the TV is setup correctly, then you may be looking at a broken Nintendo 64.
Jan 23, 2013 | Nintendo 64 Console
Nintendo 64 has power but does not work
Bring the console in to Gamestop or Rock30 Games and have them hook it up to their setup and see if it works. They buy sell and trade n64 games and will have a n64 system already set up at the store. Just switch your console and cables with theirs until you find out what is not working for you.
Jul 27, 2012 | Nintendo 64 Console
My Tv doesn't display the N64 game. No sounds come out also.
What you need to do is, first check the tv av input is working, use a dvd player or any other device with the red, white and yellow plugs.
If it works, the problem may be the nintendo AV cable, they are cheap and worth the few bucks to re live all those nostalgic game moments. If replaceing the AV cable doesnt work, check all the solder joints around the AV socket on the N64 main board. I hope this helps. Good luck.
Aug 07, 2010 | Nintendo 64 Console
Second Hand N64 seems to be dead...
first... i recommend u get a new AV connection for it... a nintendo 64 one or a gamecube one.. any one of those should work... and make sure u blow inside the opening where u put in the game and blow in the game too.. that might also be the case..
Dec 02, 2009 | Nintendo 64 Console
N64 red light
Try blowing out the Game slot on the console, and then blow out the large metal prong on the bottom of the game. Also try waiting a little bit, your nintendo might need to cool down.
After a long time n64 games fail to start up on most attempts, so keep trying, it will start up eventually.
Nov 24, 2009 | Nintendo 64 Console
N64 cartridge stopped working
try blowing inside the cartridge then cutting the game off then on if that dosnt work the cartridge dosnt work anymore happened to me plenty of times
Aug 03, 2009 | Nintendo 64 Console
Apr 16, 2009 | Nintendo 64 Console
Feb 11, 2009 | Nintendo 64 Console
N64 works but the Picture has loads of static
It sounds like it's most likely a problem with the AV cord you're using to connect to the TV or the ports on the TV where you plug it in. If you can, borrow a friend's AV cable and see if it works, if not then it's either a technical problem elsewhere or it is not hooked up correctly... Also make sure the TV is set to the correct input (Video 1, Video 2, channel 3, etc.)
Oct 17, 2007 | Nintendo 64 Console
Nintendo 64 Console Logo
3,230 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
