Question about Whirlpool Refrigerators
Whirlpool refrigerator problem
Our refrigerator is three years old and since May 28 2009 I notice that freezer works but the refrigerator section gets to only 67 degrees
  • 159 Answers
Does the motor ever shuts off if not the only problem is the gas level in the system are low
Posted on Jun 01, 2009
Top part of refrigertater not cooling. bottom freezer is ok. only about three years old.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
Freezer does not keep ice cream frozen
You are having a problem with one of the three main components of the the defrost system. Look into rear of your freezer to see if ice and frost is beginning to build up on the rear panel. If yes begin manual defrost by unplugging and remove contents of freeze. Even better send me the model number of your Whirlpool. That is how I tell you were the problem began most likely. Look around the door frame and inside the fresh food section sea Breeze
Apr 12, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
I have whirlpool refrigerator model# et9fhtxmq01 with the freezer section to the top and refrigerator section the bottom .The refrigerator section is not cooling and freezer section is not freezing ok.I...
Thaw it with a hairdryer and it'll work til you can get it fixed.
check defrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. If the heater and thermostat are ok it’ll be the control.
Sep 13, 2009 | Refrigerators
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Sep 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Back of Fridge icing up
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
May 17, 2008 | Miele KFN8762SDED Bottom Freezer...
Frost free fridge not cooling but freezer workin
My opinion.
May 17, 2008 | Whirlpool Refrigerators
Jennaire side by side refrigerator
Check the back wall of the freezer for snow on it. If present you have a defrost problem which will reduce or cut off air to cool the refrigerator section.
May 05, 2008 | Refrigerators
Refrigerators Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
