Home | Danby | DWC283BLS Wine Cooler | DWC283BLS Wine Coo...
Danby DWC283BLS Wine Cooler
Problem for Danby DWC283BLS Wine Cooler
DWC283BLS Wine Cooler running hot, won't cool properly
By hill7007 on May 31, 2009
For about 3 months temps have crept up on the lower compartment and won't go below 52 degrees. House is at 70-72 degrees at all times, unit is well ventilated, clear of dust and abut 2/3 full of wine. Compressor unit very hot to the touch. I have unplugged on two occasions hoping for a "reset" of some luck.
I see others have issues similar in blogs. Any ideas?
Comments:
May 31, 2009
- How do I check the thermostat?
Solution #1
posted on May 31, 2009
Not Rated)
e-Guru
Rank: Wiz
Rating: 84%, 259 votes
YOU MIGHT HAVE A FAULTY COMPRESSOR (MOTOR) OR A GAS LEAK.LET ME NO IF YOU NEED FUTHER ASSISTANCE ALSO THE VENTALATION COULD CAUSE IT AS YOU SAY THAT IT IS BUILT INTO THE CABINITS SO REMOVE IT
OR
If the motor are running the gas level are too low . if the motor are not running check the thermostat. if there are power by the motor and stil not running then it is the motor
OR
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again..
Also a dusty coils could cause the problem . its very important to keep the coils clean
Thank You
Solution #2
Not Rated)
spark9
Rank: Guru
Rating: 86%, 46 votes
yes it thermostat problem for sure.its fairly simple to replace, just unplug the wine cooler then take the thermostat knob off, then unmount the thermostat and put the wires on the new one as they can off the old one. click this link directly.in this model and brand is different but the system of replacing the thermostat is exactly the same.
http://www.applianceblog.com/mainforums/showthread.php?t=13373
you can order the thermostat from www.repairclinic.com or from  www.partselect.com thanks.please do rate the solution.thank you for using fixya.keep updated.
Popular Solutions for Danby DWC283BLS Wine Cooler
Questions and Unsolved Problems for Danby DWC283BLS Wine Cooler
Do you recommend Danby DWC283BLS Wine Cooler?
Answer
Answer
top evaporator fan not working and compressor hot , not cooling below 79 degrees
Answer
My Danby wine cooler DWC283BLS does not cool and the top fan is not spinning. I switched the plug on... (More)
Answer
Everything running but not getting cold. 18-months old unit. Not worked since we moved house
Answer
over the past few days seems to cycle on and off much more frequently than before, also a bit louder
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DWC283BLS Wine Cooler:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 638
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
