Question about Toshiba DVR610 DVD Recorder/VCR
Can't get vcr's to record
I have 3 vcr's connected. They all play and none of them record. Two are connected to cable boxes. I can't figure out this puzzle. One recorded until I got a cable box and reconnected it to the cable box.
  • 57 Answers
Ok heres how to get 1 to record...on the cable box look for the AVI OUTPUT hook up the red white and yellow wires to it..then hook the other end of wires to the input on vcr now change the channel on box to input u will have to use the vcr to control the channelssometimes u have to put a tape in vcr and hit play then stop to get the vcr to its stable mdode
Posted on May 31, 2009
We have a magnavox dvd/vcr player. We can't figure out how to record a program from our t.v. on the vcr. it is hooked up to a panasonic viera.
First, make sure the wiring is ok, any outside cable connection (box) wire from the out..should be plugged into the in on the dvd.vcr... and the wire out from the dvd.vcr to the tv...... now make sure the tv and dvd/vcr is both on Ch 3...........(if cable / sat this will select the ch)..... ok test it pick a channel.........press rec on the vcr,,, 30 seconds is long enough... stop rewind press play ..... yeeay.........
Oct 05, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
It says "play" and my tv is on Ch.3 but there is nothing playing. I tried turning my direct tv off but it made no difference.
do you want to record programs on your vcr? connect the out to tv cable from your dir/tv box to antenna or cable in on the vcr, then connect the cable from out to tv on the vcr to antenna or cable in on the tv, you'll have to select channel 3 on the tv to get the vcr to show a picture and you will need to select channel 3 on your vcr to record the channel selected on your dir/tv box. confusing?thanks and good luck.
Jan 02, 2010 | GoVideo Go Video DVD/VCR Combo
Are there problems recording to a vcr when using a digital converter box?
Not at all, as long as the channel selector on the back of the VCR is set to channel 3 to receive the signal and record. Connect the digital convertor box to the VCR. Connect a second co-ax cable to the TV to complete the signal loop. Tune your TV on the channel you want to watch/record. Put the VCR on channel three on the display screen. Try recording and play it back. This will ensure all your connections are correct. Hope this helps, if not let me know.
Oct 27, 2009 | Zenith VR4207HF VHS VCR
Can't record from tv
u have a cable/sateliite connection...cable from wall to cable box in...cable box out to vcr/dvd in....vcr/dvd out to samsung lcd in....(vcd/dvd and samsung must be tune to ch 3) now u should be able to record all channel (note HBO, and some others like it may not allow dvd recording) vhs yes.
if this helpful feel free to rate
Jun 16, 2009 | Sylvania DV220SL8 DVD Player/VCR
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Mar 10, 2009 | Sony Televison & Video
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Toshiba DVR610 DVD Recorder/VCR Logo
503 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
