Question about Sony STR-DE635 Receiver
Led display goes dead
My sony str-de635 led display goes dead after being on for several hours. Is there any fix for this as I am an electronics technician.   Thanks
  • Anonymous Feb 20, 2008
    sometimes my led is lit and then it goes out also my bass boost and eq buttons dont work when this happens.
  • klthms Oct 02, 2008
    I am having the same problem with mine...any luck?
  • 45 Answers
I suspect intermittent 31V supply, filament supply or bad connections on fluorescent display.
Check Q801 31V reg , R802, zener on base of Q801 located on DC board. Inspect all boards for bad solder joints, reflow and tighten pcb grounding screws.
Posted on Nov 05, 2007
Where can I get Manual for Sony STR-DE635
Sony has the user manual for the STR-DE635 here: https://docs.sony.com/release/STRDE635.PDF .
I hope this helps.
Feb 04, 2018 | Sony Audio Players & Recorders
WHEN TO TURN SONY STR-DE635 ON AND NO AUDIO OUPUT
Maybe the Preamp driver IC, looks like a car audio ic on the main board.
Often with age the heat generated by the ic will destroy the solder.Makes it look like lava rock in bar-b-que grill. Which
causes an open circuit in the preamp driver to the audio power
stage.
Simply resolder them, most often restores audio. Should have
a bottom removalble cover.
If not, a fuse normally blows if ic or channel is shorted. Check if
display will say Power off, Protect, etc. That means there is a problem with a channel.
Most Sony receivers use darlington transistors, they short easily !!
I am an old school component level service tech, I think I do have a schematic for this model and many others.
Jan 12, 2012 | Sony STR-DE635 Receiver
I have a Pioneer PL-202AZ turntable. I have to be able to plug it into my stereo receiver which is a Sony model # STR-DE635. What kind of adapter do I need? Any suggestions on where to purchase the...
I assume you mean the sony dosen't have a phono input? Then all you need is a Magnetic Cartridge Pre-amp. Your turntable plugs into this and the pre-amp goes into a spare aux on the Sony. Just do a search for the Pre-amp on google by putting in "Magnetic Cartridge Pre-amp".
Sep 19, 2010 | Pioneer Audio Players & Recorders
Have a Sony STR-DE635 that keeps blowing the 2 8 amp fuses in the power supply. disconnected all speakers and powered up with same result. Checked bridge rectifier and (2) 10000 uf caps all are good
Have you checked the rails to ground for shorts. Get hold of a variac as it does make things a lot easier.
Sound like you might have some shorted output devices.
Hope this helps
Thanks for using FixYa
Aug 18, 2010 | Sony STR-DE835 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
Sony str-de635
It may need soldering of the display, could also be a bad resistor or transistor in the power supply.
Dec 08, 2008 | Sony STR-DE845 Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
229 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
