Graphic card How can i upgrade my graphic card without buying another one?? mine is on-board  altough it is a 224mb one i cant use more dan 32 mb. wat do i have to do??
  • 16 more comments
  • cacodar May 31, 2009
    tks for your help
    how can i go into my bios
    and do i need to buy a motherboard in order to have a bigger graphic card ?because this is an on board one
      can u identify by this ?
    System Information
    Time of this report: 5/31/2009, 17:13:56
           Machine name: MS-20E2B53A4C45
       Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.090206-1234)
               Language: English (Regional Setting: English)
    System Manufacturer: To Be Filled By O.E.M.
           System Model: To Be Filled By O.E.M.
                   BIOS: Default System BIOS
              Processor: Genuine Intel(R) CPU            2160  @ 1.80GHz (2 CPUs)
                 Memory: 1016MB RAM
              Page File: 1461MB used, 984MB available
            Windows Dir: C:\WINDOWS
        DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
         DxDiag Version: 5.03.2600.5512 32bit Unicode
    DxDiag Notes
      DirectX Files Tab: No problems found.
          Display Tab 1: No problems found.
            Sound Tab 1: No problems found.
              Music Tab: No problems found.
              Input Tab: No problems found.
            Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (n/a)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
            Card name: Intel(R) 82945G Express Chipset Family
         Manufacturer: Intel Corporation
            Chip type: Intel(R) 82945G Express Chipset Family
             DAC type: Internal
           Device Key: Enum\PCI\VEN_8086&DEV_2772&SUBSYS_27721849&REV_02
       Display Memory: 224.0 MB
         Current Mode: 1024 x 768 (32 bit) (60Hz)
              Monitor: Plug and Play Monitor
      Monitor Max Res: 1600,1200
          Driver Name: igxprd32.dll
       Driver Version: 6.14.0010.4764 (English)
          DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
     Driver Date/Size: 1/13/2007 04:33:00, 57344 bytes
          WHQL Logo'd: Yes
      WHQL Date Stamp: n/a
                  VDD: n/a
             Mini VDD: igxpmp32.sys
        Mini VDD Date: 1/13/2007 04:33:18, 5672032 bytes
    Device Identifier: {D7B78E66-6432-11CF-6569-7807A3C2CB35}
            Vendor ID: 0x8086
            Device ID: 0x2772
            SubSys ID: 0x27721849
          Revision ID: 0x0002
          Revision ID: 0x0002
          Video Accel:
     Deinterlace Caps: n/a
             Registry: OK
         DDraw Status: Enabled
           D3D Status: Enabled
           AGP Status: Not Available
    DDraw Test Result: Not run
     D3D7 Test Result: Not run
     D3D8 Test Result: Not run
     D3D9 Test Result: Not run
    Sound Devices
                Description: Realtek HD Audio output
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_18491E01&REV_1000
            Manufacturer ID: 1
                 Product ID: 100
                       Type: WDM
                Driver Name: RtkHDAud.sys
             Driver Version: 5.10.0000.5296 (English)
                WHQL Logo'd: Yes
              Date and Size: 9/12/2006 13:27:00, 4381184 bytes
                Other Files:
            Driver Provider: Realtek Semiconductor Corp.
             HW Accel Level: Full
                  Cap Flags: 0xF5F
        Min/Max Sample Rate: 8000, 192000
    Static/Strm HW Mix Bufs: 33, 0
     Static/Strm HW 3D Bufs: 33, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
                   Registry: OK
          Sound Test Result: Not run
    Sound Capture Devices
                Description: Realtek HD Audio Input
      Default Sound Capture: Yes
      Default Voice Capture: Yes
                  Cap Flags: 0x41
               Format Flags: 0xFFF
    DirectMusic
            DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
         DLS Version: 1.00.0016.0002
        Acceleration: n/a
               Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                      Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                      Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
            Registry: OK
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
    Vendor/Product ID: n/a
            FF Driver: n/a
          Device Name: Keyboard
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
    Poll w/ Interrupt: No
             Registry: OK
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x27CB
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 4/13/2008 20:45:37, 59520 bytes
    | Driver: usbd.sys, 2/28/2006 14:00:00, 4736 bytes
    hi can i check from somewere else and not open d the tower?
    no :( btw r u lwys online
    custom built i think
    wer do u live
    Operating System
    System Model
    Windows XP Home Edition Service Pack 3 (build 2600)
    Enclosure Type: Desktop
    Processor a
    Main Circuit Board b
    1.80 gigahertz Intel Core Duo
    64 kilobyte primary memory cache
    1024 kilobyte secondary memory cache
    Board: ConRoe1333-D667
    Bus Clock: 200 megahertz
    BIOS: American Megatrends Inc. P1.10 05/28/2007
    Drives
    Memory Modules c,d
    160.03 Gigabytes Usable Hard Drive Capacity
    44.84 Gigabytes Hard Drive Free Space
    HL-DT-ST DVDRAM GSA-H44N [CD-ROM drive]
    3.5" format removeable media [Floppy drive]
    MAXTOR STM3160211AS [Hard drive] (160.04 GB) -- drive 0
    1016 Megabytes Installed Memory
    Slot 'DIMM0' has 1024 MB
    Slot 'DIMM1' is Empty
    Local Drive Volumes
    c: (NTFS on drive 0)
    160.03 GB
    44.84 GB free
    Network Drives
    None detected
    Users (mouse over user name for details)
    Printers
    local user accounts
    last logon
     Guest
    17/02/2008 15:30:04
     Private User
    31/05/2009 12:11:04
    (admin)
    local system accounts
     Administrator
    never
    (admin)
     HelpAssistant
    never
     SUPPORT_388945a0
    never
     Marks a disabled account;    Marks a locked account
    Canon MP160 Printer
    on USB001
    Microsoft XPS Document Writer
    on XPSPort:
    Standard floppy disk controller
    Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
    Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
    Primary IDE Channel [Controller] (2x)
    Secondary IDE Channel [Controller]
    Intel(R) 82945G Express Chipset Family [Display adapter]
    BenQ FP91GX [Monitor] (19.1"vis, February 2007)
    Bus Adapters
    Multimedia
    Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
    Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
    Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
    Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
    Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
    Realtek High Definition Audio
    Communications
    Other Devices
    Realtek RTL8139/810x Family Fast Ethernet NIC
     primary
    Auto IP Address:
    192.168.1.65 / 24
    Gateway:
    192.168.1.254
    Dhcp Server:
    192.168.1.254
    Physical Address:
    00:19:66:2C:B0:AB
    Networking Dns Server:
    192.168.1.254
    Bluetooth RFCOMM from TOSHIBA
    Bluetooth VComm Manager
    USB Video Camera
    Serial Cable using IrDA Protocol [Infrared]
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    Microsoft PS/2 Mouse
    USB Root Hub (5x)
    pcouffin device for 32 bits systems
    Virus Protection [Back to Top]
    Norton Internet Security Version 16.0.0.125
        Realtime File Scanning On
    Missing Microsoft Security Hotfixes [Back to Top]
    All required security hotfixes (using the 05/12/2009 Microsoft Security Bulletin Summary) have been installed.
    tks a lot for ur help !!!!!!!!!!! i really appreciate it
    btw i m from malta
    how can i do this
    i did it. tks again for ur help
    hi i opened it and it does have d yellow one. so is d one of ebay gd for it?
    and is it difficult to install it??
  • cacodar Jun 02, 2009
    hi wen i opened again d pc i found only yellow slots. r these slots exactly like d yellow ones????
    President:
  • 1,314 Answers
1. You cannot upgrade your graphic card without buying another one.
2. Your onboard card "shares" the memory available to the computer so it is not actually a 224 MB one as it shares the memory the computer has. To up the amount of memory your onboard graphics uses, go into your computer's BIOS and adjust the size there. Doing so, however, will decrease the amount of system RAM available and, with only 256 MB memory it will run even slower than it is running now.
Posted on May 31, 2009
  • 8 more comments
  • Kevin Shafer
    Kevin Shafer May 31, 2009
    To get into the BIOS is different for many computers. Usually you need to press one of the following keys when you first turn on your computer: DEL, F1, F2, or F10 but I have seen other keys and key combinations as well. When you first turn it on, it may tell you what key to press....It may say to enter BIOS, CMOS, or system settings press and then tell you which key.
  • Kevin Shafer
    No, all you need to do is purchase a graphics card that will go into an available slot into your system; the computer will automatically bypass the onboard graphics and use the graphics card instead. I cannot say which one will work for you unless I know your computer make and model or your motherboard make and model.
  • Kevin Shafer
    That gives me an idea, but it's not 100%.
    Look at this picture.
    Now look inside your computer. Do you have a slot exactly like the long yellow one? Or, does it look more like this brown one:
    If it looks like the yellow one, then that is a PCI express slot and you can get really great graphics cards for that.
  • Kevin Shafer
    Do you know what brand and model of computer you have?
  • Kevin Shafer
    Not always; about to leave for work shortly.
    Is it an HP, Dell, Gateway or a custom built?
    You can try and download a tool called Belarc advisor and it may tell you what I need to know.
  • Kevin Shafer
    I'm looking specifially for the brand and model of motherboard; can you find that in there anywhere?
  • Kevin Shafer
    I'm in Indiana. I'm pretty sure that you do have a PCI express slot because you have a dual core cpu. That being the case, the ebay link you sent me would work but I can't be 100% unless you open it up. You should be able to take the side off without shutting down your computer if you have enough room to get to it.
  • Kevin Shafer
    Your welcome! Please take a moment to give this a four star rating. Thanks!
  • Kevin Shafer
    Click on the link to give me a rating, thumbs up, then yes, I solved your problem when it asks. (I think....they've changed it so many times and I'm not on the question side of the site :c)
  • Kevin Shafer
    No, they are not difficult to install. You just put it in the slot and run the CD. When you first boot it up the resolution will be really large and the colors may even be off; just run the install on the CD and it will install the driver then when it is finished it will reboot and you'll be taken care of.
No picture possible video card?
possible, to run a 32 in monitor you need at least a 256 graphics card, if your comp has the board mounted 224mb intel chipset that might require a different card
Sep 18, 2010 | Dell W3201C 32 in. LCD Television
What is the max graphic card capacity for mercury mainboard pi945gzd
Graphic Integrated Intel Graphics Media Accelerator 95 (GMA950) Max Dynamic Video Memory up to 224MB(System Memory greater than or equal to 512MB)
Jul 09, 2010 | XFX GeForce 6800 GT, (256 MB) Graphic Card
My acer 3690 laptop need a graphic card upgrade
no you cant upgrade a laptop graphics card
Jan 22, 2010 | Acer Aspire 3690 Notebook
Your card or driver does not support directx9.0c 3D acceleration
Time for a video card upgrade. You are now two (almost 3) generations of video cards behind.If you are truly referring to a VooDoo card, you definitely need to upgrade to something newer. If the game you are trying to play says you must have a DirectX 9.0c compatible card, you will need to get a new video card. The good news is that just about any card you can buy new would be at least DirectX 9c compatible. The bad news is, I am guessing your card is PCI card. That being the case, you will be hard pressed to find a new one for sale.
Aug 10, 2009 | 3dfx Voodoo4 4500 (32 MB) Graphic Card
Pci
no you cant the s3 Trio 3d/2X have only 8 mb, you can exchange it?
Sergio
Mar 26, 2009 | Computers & Internet
32 mb ATI Rage 128 Ulta upgrade
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101565
The documantaions say thar you have an APG-port, i cant see any problem why you couldent upgrade it...if u can find a card.
Good luck
Nov 19, 2008 | Ultra ATI Rage 128 Pro Graphic Card
Dedicated graphics card
nopes..with intel media accelerator u cant upgrade to a 128 mb graphics card or whatever higher memory cards for that matter..there is a studio 15 laptop with 256 mb ati graphics..probably u should hav got that..
Oct 17, 2008 | Acer AOpen MX 400-A (32 MB) Graphic Card
Drivers upgrade
as far as I know, it's impossible to upgrade Graphic Card shader model 2 to 3. Buy a nVidia card (instead of ATI) because it has shader model 3. The cheapest one is below $50.
Aug 06, 2008 | ASUS A9550GE/TD Radeon 9550 Graphic Card
Upgrade laptop
Hi
Only you can upgrade laptop ram and hdd. You cannot upgrade your graphic card, try to upgrade your ram it will improve speed....
Apr 01, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
798 people viewed this question
David Payne
David Payne
