Question about Dell Dimension 9100 PC Desktop
Computer OS won't load
Turning computer on Windows ''loading'' screen appears as normal then screen goes blank.
Have run all diagnostics in set up screen and all pass
  • sevans907 May 31, 2009
    tech4222 has the right answer. I downloaded DirectX onto my desktop and it never activated. When I shut the system down and restarted is when this problem started.
    Now I can't get to any screen to set the driver back to the default system driver -
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Is the screen really blank, or is it blank with a little blinking cursor at the top left?
  • 40 Answers
This could be a video card problem. Can you hear the Hard Drive working and/or see the Hard Drive light flashing? If so your OS is loading but the video card is failing. Check your cmos settings and try unplugging the monitor cable from the video card and plugging it back in. If you have another card swap it out.
Posted on May 31, 2009
  • Charles Canarr
    Charles Canarr Jun 01, 2009
    Do you know how to get into Safe Mode? as the pc is booting up hold down the F8 key, It will bring you to an option to go into Safe Mode with Networking. This will load the basic drivers to allow you to fix the video problem. Hope this helps.
    Sergeant:
  • 145 Answers
Yes, I think your memory is the problem, it's crash
it is hardware problem, not system
  • 822 Answers
Check the RAM.
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Windows 7 won't load
try going to the bios screen and re installing the windows
Jan 31, 2013 | Acer Aspire One PC Notebook
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
I have an HP dv9040us with nvidia GeForce Go 7600. My issue is regarding the display. The screen either goes black or goes black and draws vertical lines. I can run the computer in safe mode and after...
Hi
It seems that you need to use the latest driver for the graphic card.
You can do that through visiting the manufacture's website, choose your laptop model, OS, look for video (vga) driver, and download it.
Please tell us your results
Good Luck
May 15, 2011 | HP Pavilion dv9040us Notebook
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
I am working on my friends gateway mx6450 laptop when you turn it on it goes to a blank screen after the welcome screen. I have tried to run on safe mode. It goes to a blank screen with the safe mode...
1. Refresh the screen: Right-click on the desktop and select [refresh]
The icons will appear.
if not,
Boot to the Safe Mode screen and select "Start in Last Known Good Setting"
Nov 13, 2009 | Gateway MX6450 Notebook
The monitor comes on then goes out.
Problem with appearing normal windows desktop... go to Safe Mode to remove any possible pop-ups or vga driver to see where the windows stands normally.
Oct 04, 2009 | HP Compaq FP5315 15" LCD Monitor
Screen goes blank
Try to load to safemode by restarting the pc and hitting F8 before loading the windows, after you load to safemode right click on desktop screen and hit properties and check if you change the size of screen?or the setting there? also look for the device manager of your vedio card and check if it works properly.
If all this not working this means your vga converter has problem this is card inside your laptop mostly happen with dell laptops, if you donot want to change it now, try to see if you have external screen port and connect your laptop to external screen.
Let me know wat happen?
Best Regards
Mar 02, 2009 | Dell Inspiron 9300 Notebook
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
What's wrong with my computer
Yes. You have a very sick VGA card in your computer. Get it replaced. The reason it runs okay in safe mode is because full potent driver and graphics don't load in safe mode to aggravate the card's illness. When the driver fully loads in normal mode, the card freaks out.
Good luck
Feb 18, 2008 | Televison & Video
Dell Dimension 9100 PC Desktop Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
