Question about Garden
Can't figure out how to install main drive belt on riding mower.
The main drive belt broke on my mower and I am not certain how to install the new belt. It appears that to route it properly that I will have to remove some parts as the belt goes around them. Help!
  • STEVE LESTER
    STEVE LESTER May 11, 2010
    what kind of mower do you have.most mowers if you were to drop the deck as to cut.look toseeif you have two bars with pinn throuhg them you can remove those pins and slip the belt in that way without a major tear down.(please rate this)hope this helps
  • Dwain Pippen May 11, 2010
    In order to help, we need to know what kind of mower and MOST importantly, what is the model #, usually located under the seat.
Usally if you look on the bottom of of your mower deck it will show you the route you need to go
Posted on Jun 02, 2009
Was cutting grass and mower just quit pulling
sounds like the drive belt broke you need a new belt
Jan 29, 2013 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Finding replacement belt from UK for McCulloch hornet ride on mower
Just in case anyone else comes across this in searching for a Main Drive Belt or a Deck Belt :-
Marksman Industrial Ltd
Main Drive Belt 1134.9013-01 (see also 9585-0057-00)
External length 888 mm
"STIGA 1134-9013-01 Equivalent Belt" Kevlar reinforced
Deck Belt 1134.9032-01 (see also 9585-0075-00)
External Length 1219 mm, Pitch Length 1206 mm
4L480K - 1/2" x 48" Kevlar reinforced
Note:
Stiga Garden Combi is pretty much an identical mower
Hope this helps someone.
Aug 01, 2012 | Garden
I need to install a new drive belt on a GT 275 Belt broke while mowing. Got new belt but it is not obvious how it goes on.
lay under the mower and look for a diagram - there should be one somewhere on the unit.
Gary @ Fix Ya
Sep 19, 2010 | John Deere Hood Gt242gt262gt275 Garden...
Belt broke on riding mower and I don't know how how it goes back on
Go to Sears and take a look at how the belt is routed. After you get it figured out take a sharpie and mark your deck so you don't have the same problem again. When you buy a new mower mark it before you have to replace the belt.
Aug 19, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
How do i replace the hydro belt on the swisher zt2660? my belt broke after 35 hours. when i put the new belt back on it was loose and i can't figure out what needs to be tightened. i also find it very...
A mower with 35 hours should still be under warranty, and a belt shouldn't break at 35 hours unless you ran over something that got caught in the belt. I would take this unit back to the dealer - it is their responsibility to repair or replace your mower.
Here is my advice on how to change a main hydro belt. To get enough room to work, jack up the back of the mower (put blocks in front of the front wheels first) then make sure the back end stays up with jackstands under the chassis, or use bricks or blocks under the rear wheels. No matter what, you'll be laying on your back working in a cramped space. So don't tackle it if it's the dealer's responsibility.
If you've replaced the belt but can't get it tight, check that the idler arm spring is hooked up properly so the idler pulley presses in on the belt to tension it.
Jul 14, 2010 | Swisher Zero-Max 60-Inch 26HP Zero Turn...
Cahnging drive belt on mower
dont understand your question ... get the belt ... it was designed to fit ... there are probably at least three pulleys. put the belt around the motor pulley and the trans pulley then figure out how the clutch or tensioner pulley interact with it.
May 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The drive belt on my old john deer riding mower broke how would i fix
need to purchase a new belt should be numbers on it too get the right one after getting it it will fit round the pulleys under the mower from the main drive to go round a tenshoner to end up round the blade pulley just need to figure its ruote round the pulleys the tensioner pulley is the last one to fit it on as you need to pull against the tension to get the belt to go round
Sep 29, 2009 | Garden
Drive belt broke murray riding mower how do i put one in?
yes the drive belt is the bottom one it looks hard but is really simple the main thing is you have to look rite above the left back tire and remove two 5/16 bolts with an 1/2 in wrench to in stall drive belt the you install other belts
Aug 08, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
303 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
