Question about Nokia 7610
Radio works well in headset mode but has a lot of disturances in loudspeaker mode
My radio works well in the headset mode but there are a lot of disturbances in the loudspeaker mode.what do i do??
    Guru:
  • 523 Answers
Hi Friend,
When u are hearing the Radio or Music Player in your mobile by using the headset its clear but when u are using thro' loudspeaker its not clear because of below reason,
1.There may be problem in the Speaker(LoudSpeaker).The Solution is u may change your speaker by giving to the Service Center.
Regards,
Ayyasam
Posted on May 31, 2009
My nokia n73 radio is not working what can i do for this problem.
There is the possibility that the earpiece of your headset is bad. Try putting the rdaoi on loudspeaker, if it works, then you either listen to the radio on loudspeaker, or get another headset that is in perfect shape.
But if putting it on loudspeaker still does not work, then you have to entirely change your headset to another.
Hope that was helpful?
Thank you for using FixYa.
Aug 30, 2011 | Nokia N73 Cellular Phone
I want to on fm without Head phone...i need code.
If you mean Nokia 2310, I don't think it's possible to play radio without headset connected to the handset. I don't believe, nokia has ever developed such a model and moreover it's impossible to play radio on nokia phones via bluetooth. If you mean other model, do let me know. Or is there any other application installed on your phone to run the radio? But in fact the handset needs the headset to run radio, so that i'll act as an antenna. Somebody uses the cut-out jack of the headset to play radio. You can try a trick, play the radio, put on the speaker (loudspeaker), then remove the headset, if it's working you are lucky. But even with Nokia N95, it's not working.
If you are sure that you are asked a code to access the radio without headset, let me know with more details.
Thanks.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Nokia 2310 Cellular Phone
I have nokia n85 i can't hear anything when i use headset
hi, try change your ear piece...it faulty.
cheers
May 29, 2010 | Nokia N85 Cellular Phone
Hands free instructions wanted Icanget to enhancement in settings' Also to headset and handsfree but despite gong to hands freee mail 0795177 4535 it does not work I can get to enhancement through settings...
You can use the headset enhancement directly when you make a call but for the hands free mode, your phone doesn't support that feature. Only nokia 1112 and above support hands free mode or it's loudspeaker mode but not in nokia 1100.
Hope this makes it clear for you.
Thanks..
Mar 31, 2010 | Nokia 1100
My phone is at headset mode. but i do not have a headset. thats why i cannot hear the other person on the line. so how can i put it back to handsfree mode? wherein i can use the loudspeaker and all?
Sometimes dirt/debris gets in the headset jack on the phone causing the circuit to close which makes it think there is a headset in it. Try to take a headset and insert and remove it a few times to get the contacts unstuck. Liquid damage can also cause this problem.
Nov 13, 2009 | Nokia N70 Cellular Phone
Can't hear caller or people I call unless I hit speakerphone
This is the problem the speaker on your phone, I will give you some tips to clarify this
* try with the hands free (if you have)
* try with the loudspeaker mode.
If it works good in these modes, then you got to replace the hearing speaker.
Jul 21, 2009 | Sanyo Katana SCP-6600 Cellular Phone
No sound in handset mode but working fine on loudspeaker
YOu know,its all right with ur phone,but the headset may not be supported by the phone,i mean its enhancement cant support the headset model. change it and it might work.
Jun 10, 2009 | Nokia 3120 Cellular Phone
Loud Speker Not working in Radio FM in LG KU990 VIEWTY
unfortunately, this option is not available on viewtys, however - if you bring up your phones keypad and dial 3845#*990# (don't press the call button after) you'll be presented with test mode, use the cameras jog wheel to scroll down to FM Radio test. Now, if you're lucky - you'll find a VERY strong radio signal that the viewty can pick up without the headphones in, and it'll play it through the speaker. But otherwise, you have to have the headset in to get a good signal, and if you have the headset in, there's no option what so ever to divert the radio to the speaker. So Sorry, but the radio can only play through your headphones unless you're lucky with test mode. (press the "C" button when in test mode to return to the home screen)
May 19, 2009 | LG KU990 Viewty
Loudspeaker Nokia N81 - 8 GB
do you have ab luetooth headset connected?
if so try closing the connection..
May 21, 2008 | Nokia N81 Smartphone
Headset problem with Uniden 1558
Determine if this is a VOX problem or a headset problem.
Turn off the VOX. Does the headset work for normal transmit and receive?
Remove the headsets. Do the radios work normally on speaker?
Plug one headset in And test with the (other) radio in speaker mode. Does it work? Now turn on VOX in this mode (yes it will work this way). Does vox work (put you mouth right on the mic)
If so swap headsets and try the other.
If one Hset works but not the other its the headset. If neither works its likely the radio ..but before you decide try the same headset experiment on the other radio. Find out which of the 4 devices the problem follows.
Happy New year
Dec 24, 2007 | Uniden GMR-1558 / 2CK 2-Way Radio
Nokia 7610 Logo
94 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
