Question about Cobra Cameras
After taking 3 or 4 pictures my batteries die
My Cobra digital camera uses up batteries after just a few pictures.
SOURCE: stealth cam digital game camera not taking night pictures
i opened up the unit and found the wire from the cover had became loose from its soldered point, where does it go so i can resolder it.
Posted on Sep 04, 2008
SOURCE: Samsung Digimax L730 Digital Camera
This problem is usually caused by grit in the mechanics of the lense. To resolve the problem:
1. Ensure the lense itself is clear, removing any visible objects.
2. Try tapping / knocking the camera to dislodge any obstruction.
3. Failing this you can force the mechanics by turning the lense sections - however be careful when attempting this as you may snap the lense if turned too hard or the wrong way.
Words of wisdom from: Malhotra, Manmohan
Posted on Nov 05, 2008
t00nz
  • 4738 Answers
SOURCE: Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Posted on Jul 21, 2009
leepania
  • 1099 Answers
SOURCE: batteries in my kodak easyshare camera don't last
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 09, 2009
  • 11967 Answers
SOURCE: Camera died while taking pictures. Lens is open.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 04, 2010
Chargin batteries before the camera dies
what is your question? Do you charge batteries before the camera dies? Yes, you can if you are using Ni-MH batteries. these are the only rechargeable batteries recommended for this camera. I would not leave them on the charger full time just when they need it and to freshen them up if they have been sitting awhile. The old rule use to be that you should run your batteries down once in a while, this is not true anymore. Batteries have changed since than. With a camera like you have I would recommend you keep a spare set or two of alkalines with you. this gives you a nice backup for when those batteries run down on you. If your camera is very good on batteries and you only take a few pictures now and than alkalines may work better for you. I use to have a Canon A70 that used the same batteries. It would at least 300 pictures off a set of batteries. For me rechargeable batteries were a waste, depends on the camera and your usage.
Sep 02, 2009 | Fuji FinePix S7000 Digital Camera
COBRA DC6550
Hi ill have a look now for you and let you know what you need to do ok bare with me for few minutes ok
Feb 12, 2008 | Cobra Digital DC6550 Digital Camera
Tip
This camera sucks. It takes horrible pictures, you know the 2 or 3 you can snap...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Apr 25, 2009 | Samsung Digimax D53 Digital Camera
Will not take more than a few pictures.
I had the same problem using a Play.com 8Gb SDHC card. I replaced it with a SanDisk 4Gb SDHC card and the problem hasn't reoccurred.
Seems these cameras don't like "cheap" SD cards.
Feb 10, 2009 | Kodak EasyShare C913 Digital Camera
Cobra DC125 after 5 pics LCD flashes "FL"??
The mode was selected for Hd, just change it to Ld and it allows you to take more pictures.
Feb 07, 2009 | Cobra Digital DC125 Digital Camera
Memory full
Did you format the disk using the camera ?Try this link. http://cobradigital.com/manuals/1/DC325.pdf
Nov 22, 2008 | Cobra DC325 Digital Camera
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Feb 11, 2008 | Cobra DC4200 Digital Camera
COBRA DC6550
Hi , replace full charge battery , rotate knob to manual,press function set ,navigate down select awb, hen press navigate right select what ever liht you are using indside the house if bulb select bulbthen press function set.
use also 100 iso , metering number set to "o" , colors set to "colors off"
Dec 09, 2007 | Cobra Digital DC6550 Digital Camera
Cobra DC6550 camera
you need to insert the memory card in the slot in the bottom of the camera until it clicks
Oct 24, 2007 | Cobra Digital DC6550 Digital Camera
Cameras Logo
29 people viewed this question
Top Cobra Cameras Experts
ray gallant
Tom Chichester
Are you a Cobra Camera Expert? Answer questions, earn points and help others
