Question about Garden
How do you restring a stihl weed trimmer?
It is an double sided trimmer tat is suppose to restring itself but i cant figure out how to restring it
  • 76 Answers
SOURCE: weed eater
Hi
check the following link
The idea is the same for all trimmers
http://www.youtube.com/watch?v=WFu66Q6J62Q
good luck
Posted on Jul 20, 2009
pumpkinman
  • 1144 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
  • 16 Answers
SOURCE: Fix Coil Start Stihl Weed Trimmer
you dont say what model Stihl, lets assume its FS80/85. the torxs style screw driver is part of the tool kit supplied with the machine and includes spark plug spanner 3/4 AF, remove the four screws to release the starter assembly, the starter also retains the fuel tank, dont lose the oblong rubber insert or the tank will wobble around when assembled. if the rope wont return the end of the rewind spring may have broken off or it maybe that the spring has got so rusty its just hanging up. with the recoil off remove the centre screw (normal anti-clockwise) holding the starter away from your eyes, withdraw the pulley and inspect the spring for damage which normaly occurs at the end that engages with the pulley, if it's broken and you cant get a replacement use a pair of pliers to grip the spring about 3/4 inch from broken end, heat with blowtorch to soften and rebend into a hook to engage with the pulley, dont try to bend without softening, clean off any rust with wire wool and re-install the spring in it's housing working from the outside toward the middle.it's more of a knack than anything else and you could probably do with eleven fingers. having installed the spring make sure the rope is fully un-wound and insert the pulley into the housing turning gently until you feel the spring engage, you will know you've got it right when the pulley attempts to rewind, fit the pulley retaining screw, you will observe a notch in the outer rim of the pulley,make sure that the rope is in the notch and use it (the rope) to wind the spring about five times, check that the whole rope rewinds into the pulley, if you still have some hanging out put more turns on the spring but dont over do it. to check, gently pull on the grip until you come to the end of the rope, thats the important bit, you must come to the end of the rope before you come to the end of the spring otherwise the spring will break again.install the starter assembly by offering up and slowly pulling on the grip until you feel the pulley engage with the starter pawl. good luck.
Posted on Aug 31, 2009
  • 5 Answers
SOURCE: how to replace coil on stihl fs85 weed trimmer
Remove the starter & cylinder cover and look for the coil mounted next to the flywheel. Remove the 2 screws holding it to the cylinder and cafefully pull the wires through the clips that hold them to the block. Install the new coil in the reverse order and set the air gap between the flywheel and the coil with a business card. Let the magnets on the flywheel pull the coil towards it with the business card in between. Tighten the screws and spin the flywheel to remove the card. Reassemble the stater and blower housing.
Posted on Sep 17, 2009
mindreader
  • 578 Answers
SOURCE: stihl fs200 weed trimmer starts hard. coil
Dirty fuel filter, dirty carb, dirty air filter.
Spend 1.50 at walmart for QuickStart fuel starter fluid.
It is ether - and will start any working engine quickly.
Suggest adding about 1/2 oz of fuel system cleaner (also available at walmart automotive section) to clean up the fuel system.....
Choke works, I assume.
Posted on Nov 01, 2009
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Stihl power pruner serial number
The serial numbers on the FS130, HL90K,HT101 and BG55 would be on stickers if they are still there... The MS250 serial numbers are located on a 'flat' by the side of the exhaust and sprocket cover. (depending on the year of manafacture)
Jun 27, 2013 | Stihl Garden
Restring stihl fe55
easy spool head or not??? your owners manual has directions.
Sep 02, 2012 | Stihl Fe 35,40,55 & Ec70 Electric...
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
I have a double string trimmer I cannot figure restring
Hi
check the following links :
http://www.ehow.com/how_2241527_change-string-lawn-trimmer.html
http://www.youtube.com/watch?v=SuGfDNH6fXk
Theses are just two, there are plenty of videos out there that shows how to resting trimmers
Hope it helps
Jul 17, 2009 | Ryobi Garden
Garden Logo
512 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
