Question about Acer Aspire 3680 Laptop
Acer aspire 3680 laptop will not charge while plugged in wall
My laptop battery was low and it said to plug in wall to continue working, well i did but it still went dead and now i cannot get my laptop to come on. is it my charger? the green light is showing on my charger when plugged in.
  • Anonymous Mar 31, 2014
    My laptop will not come on even when plugged into wall charger
  • 822 Answers
Check your charger and dc jack.
Posted on May 31, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer 3680 won't power on even when plugged into the wall
try doing power drain by disconnecting all the cables and battery then press and hold down the power button for 1 min then , check for working if not , you need to service the system
Jul 03, 2010 | Acer Aspire 3680 Laptop
Aspire 3680 Won't charge
Have you tested the A/C to be charging correctly ? Have you confirmed that at the back of your laptop where you plug the power in that the pin is not bend and not missing or broken or pushed in ?
If your new battery and the old battery give you exactly the same issue, then most likely your A/C power adapter or cable OR the physical port on your laptop is broken and needs to be replaced.
May 14, 2010 | Acer Aspire 3680 Laptop
The aspire 3680 will not trun on. battery will not charge. even with the charger plug in
plug unit into wall remove battery boot computer. if it boots up you will need to replace your battery
Nov 14, 2009 | Acer Aspire 3680 Laptop
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
It appears that you have faulty laptop power connector socket.
This is why it appears to work sometimes when you plug the connector into the laptop in some direction.
To confirm this, wriggle the connector while you look at the charge light on the laptop, if it blinks as you wriggle it then the power socket is either faulty or just needs resoldering so it will make proper electrical contact.
You can get a compute techo to do this or you can do it yourself but it requires dismantling the laptop completely to get at this power socket.
Jun 01, 2009 | Acer Aspire 3680 Laptop
My acer 3680 laptop will not power up with or with out battery/plugged ito power. Used 1 day and would not turn on the next, laptop has not even done 20 hours work over a period of time. very disapointed...
Do you get a power light when its plugged in? If not its likely the power adapter is bad and thats why it doesn't work on battery...never got charged.
Mar 08, 2009 | Acer Aspire 3680 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
507 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
