Question about GE Heating & Cooling
Wires I purchased a motor for a Fedders A/c unit. The old motor has 3 wires ,1 yellow,1 black,and 1 brown.,the new has 1 yellow, 1 black and 2 brown. What do I do with the second brown wire?
  • clanervin May 31, 2009
    Is there a jumper wire? What do I do with it?
  • 24 Answers
2 brown wires go to a split capacitor if you have a dual cap which has three terminals marked comp fan com if u have this type of capacitor then the brown wire goes to fan and the brown and white gets capped with a wire nut. whenever replacing a fan motor you should also replace the cap or at least check the capacitance to see if it is still good. you have to check it with a meter that test microfarad.you can get a permanent split capacitor and mount it in there then u use the brown on one side and the brown and white on the other side it only has 2 terminals.
Posted on May 31, 2009
  • shizznat Jun 01, 2009
    no jumper wire is needed
Blower motor installation
just check the wiring diagram and connect the two wires for the desired speed and put a wire nut one the third one.
Aug 08, 2014 | Emerson NEW A/C Fan MOTOR 1/4 1/6 1/8 HP,...
Old motor wires are numbered new motor wires are colored this is a 1/2 hp reversing motor for a overhead door
Single Phase Terminal Markings Identified By Color: (NEMA Standards) 1-Blue 5-Black P1-No color assigned 2-White 6-No color assigned P2-Brown 3-Orange 7-No color assigned 4-Yellow 8-Red
Mar 02, 2014 | Computers & Internet
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
How do you hookup a universal hvac condeser motor the old one had a black wire,red and a brown wire plus the green&yellow ground the new one has a black wire a yellow then it has back connetor thats...
WHAT??? Did the new motor come with a wiring diagram? Typically you will either be using a "3 wire" connection or a "4 wire" connection. 3 wire is for using the existing capacitor (provided it's the right size), 4 wire is for using a separate capacitor. You should have 5 total wires on new motor HIGH/LOW/COMMON/CAP & CAP. Then possibly some separate wires for ground and rotation. The ground goes right where you mount the motor, rotation...make sure its blown up and out of the machine. 3 wires would be...1 SPEED 1 COMMON 1 CAP. 4 wire would be 1 SPEED 1 COMMON 2 CAPACITOR WIRES. Good Luck!!
Apr 10, 2017 | Heating & Cooling
I have a new fan motor for a ge for a ac unit for outside home and the old is a 4 wire and new is a 3 wire has black,yellow,brown the old 1 has black,brown,red,blue or purple wire how do i rewire thie...
this soounnds as though it for a 2 spped fan motor look at the old motor and see the RPM and then look at the new motor plate it shuld show ou which wire is for the speed required. Hope this helps ..Jon
Jul 25, 2011 | Heating & Cooling
Replaced fan motor for outdoor ac unit old fan has blue,black,red,and green wires new fan has brown,black,yellow,brown/white and green what goes where
Hi, the 2 - brown wires are for there own run capacitor they should have sold you. One of the browns will have a white stripe. The new cap has only 2- terminals and you put a brown on each side. The black and yellow wires are both hot which 1- will go to 120 volts on the load or out side of the contactor, and the same with yellow, 120 volts. This gives you 220 volts to run the motor. Look on the new motor and you will have a diagram or on a paper that comes in the box. The old motor used the dual cap to run the compressor to. The green is just a ground wire. Screw it to any metal part or screw. You should be able to put the black and yellow hot wires where the old black, red, or blue were as long as they are 120 volts which I am sure they are. Get a cheap tester when you go get the cap for the new motor, and check the old blk, red, and blue terminals to ground and you should have 120 volts on at least 2 of them. Put the new yellow to 1 and black to another, browns to the new cap and your off and running. Keep me posted. I do this everyday. Please be kind when rating me, thank you.
Shastalaker7
A/C, Heating Contractor
Jul 09, 2010 | Heating & Cooling
Unsure of capacitor terminations for ao smith condensing fan moto
Does the motor data plate say anything about the motor. You can hook up a motor like yours with 3 wires. First use an ohmmeter and check the resistance between the brown/white wire to the black then the yellow wire. The resistance between brown/white and one of the others should be pretty much 0 ohms. If not check between the brown wire and the black and the yellow. Which ever wire has 0 ohms with the brown/white wire is the common leg. You can put a wire nut on the brown/white, it will not be used. Next the brown should be for the start winding and the other wire left over will be the run winding. Then connect the common to L2. L1 will go to the run winding and one side of the capacitor and brown will go to the other side of the capacitor. I hope this isn't too confusing. Let me know if I need to explain it better.
Jun 09, 2010 | Heating & Cooling
I am replacing the a/c blower motor and capacitor. The old motor has 1 brown wire to the capacitor, 1 yellow wire to the capacitor (the yellow then loops from the capacitor over to the wiring panel), 1...
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Apr 27, 2009 | Heating & Cooling
HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
192 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
