Question about Miele 23 in. Novotronic G841 Built-In Dishwasher
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
My husband has tried all the advice but to no avail. The dishwasher has been pulled out but it won't drain. The intake/drain light is still flashing, Could it be plugged inside the dishwasher? The intake drain light keeps blinking, and the pump keeps running. I have tried everything in the manual. There must be water in the safety pan under the dishwasher. How can I fix this???. I have some experience in repairing appliances, but never a Miele Dishwasher. I am very hard hearing and really can't hear well on the phone, and don't want to call Miele.
    Problem Solver:
  • 5 Answers
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
Posted on Aug 11, 2009
The intake light comes on and the machine will not go thru cycle, it just hums.Water does not drain.
its obvious the drain pumps blocked, rempty machine, remove drain plug, wire mesh scoop water in middle, then take off the plastic cover with a steel like wire on it, clear out the **** blocking the pump, assemble then should be ok.
Jun 14, 2011 | Miele 23 in. Novotronic G841 Built-In...
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
My Miele Platnum dishwasher is not working. It is flashing "intake/drain" When it begins instead of the normal hearing of water moving around you just hear a humming. My husband and father took out all the...
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 03, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele Intake/Drain light on/flashing and the dishwasher just shuts down.
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage.
Hope this helps.
Nov 22, 2009 | Miele 23 in. Novotronic G841 Built-In...
Intake/drain light on
This happens to me occasionally. There is a long thin bottom panel along the floor. Then there is another panel behind it. Behind, there is a pan that holds water. If too much water gets in that pan the intake/drain light comes on. Take those two panels off, feel in the pan, if there is water pooled, then wet vacuum the pan dry. That solved my problem and saved me about $200. I got that info from the miele advisors. That is what it is about 90% of the time if it isn't that intake valve.
Aug 13, 2009 | Miele 23 in. Novotronic G841 Built-In...
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
Intake Drain Light
My Miele Incognito dishwasher kept getting an error with intake/drain light. The light flashed 5 times. Phoned Miele Technical Support to investigate the problem. The problem is that a seal in the bottom of the dishwasher has failed and there was water in the motor pan. Currently, $175 service charge for the technician to come look at it.
I don't want to spend $175+ to have them replace a 75 cent rubber gasket that I could replace on my own.
Feb 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele 23 in. Novotronic G841 Built-In Dishwasher Logo
1,534 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
