Question about Kenmore Dryers
Kenmore dryer does not turon on
I have a kenmore heavy duty super capcity dryer that is about 7 years old and it will not turn on anymore. It has been working just fine and then over night it seems to have died. I dried a load 2 nights ago and it went through the whole cycle and the clothes dried then next morning I went to put a load in and nothing happens when I hit the start button. I have check the outlet and the breakers and all are working and getting power just fine. Now I don't know what to do. Please help, THANKS!!!
kenmore heavy duty supercapacity electric dryer
model # 110.62612101
  • 6,784 Answers
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
Posted on May 31, 2009
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Heavy Duty Gas Dryer turns on but drum won't move - is this likely a belt problem? Dryer is about 12-13 years old. Model 75651
Good day,
Reach in, and see if you can move the drum. It will be a little stiff, but should turn.
If so, yes, it is probably a belt.
Look below. (Yes it is made by Whirlpool).
If hyperlink won't work, then copy and paste it in the address bar of your browser.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 10, 2009 | Kenmore Dryers
Won't spin anymore. Comes on, but barrell won't spin. dead motor?
Do you hear the motor running? It may just be a broken belt. If it is in fact the motor it can be replaced.
May 28, 2009 | Kenmore Dryers
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Turn off buzzer
Assuming you mean the end of cycle alert. The only way to do this is to follow the wiring diagram and install a switch to cut it off.
Dec 20, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
175 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
