Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
What speaker can i use?
Have to replace speaker in one of g2`s paper ripped which speaker do i order i know i`ts 300 watts 15 inch. but what is the part # and where can i buy, not too expensive, i heard you just can`t put any 15speaker in because i`ts powered and it needs certain one , is this true? joe peixoto
    Problem Solver:
  • 19 Answers
Joe, the simplest solution <and least expensive> is to remove the ripped speaker, google "speaker re-coning" in your area and have it re-coned by someone local. It's much less expensive then replacing it. Please rate my answer, thanks.
Posted on Jun 18, 2009
What amp for a Pioneer TS-W304C 12 inch sub
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Power handling range is 50-300 watts. And a peak of 600watts. That does not mean start cranking 600watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms.
Hope these specs help you in choosing an amp.
Jan 07, 2013 | Car Audio & Video
What amp for a Pioneer TS-W304C 10 inch
Wow, i just answered a similar question so, pretty much the same answer.......
Your speaker, based on the model number you provided, is rated at 4 ohms .Nominal power handling range is 300 watts. And a peak of 600watts. That does not mean start cranking 600 watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms. Leaves you a little headroom on the amp, but use caution.
Jan 05, 2013 | Pioneer TS-W304C Car Subwoofer
I need to buy a tweeter for my speaker can you help me.
hi,
As it hve a horn tweeter no need to replace the whole unit. You will get the diaphragm. go the following page check the third item. Its the diaphragm for JBL EON 15-G2. An the order code is
DT-004.
http://www.goodhifi.com/MyDias/Diaphragms.htm
ok
Aug 03, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
My speakers r not working. The wires that attach to the speaker are ripped on my 15 inch 800 watt speaker. can i return them to M A
on some cases you can but if its your falut that they ripped more then likely they want to repair or replace and you have to have a warranty on the subs to have them do anything with them so car place will soilder them back together if there some wire coming off the sub
Sep 20, 2010 | MA Audio Car Audio & Video
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Just want to knw the speaker size for an 01 altma
Go to ANY stereo place, they will know, because they have to know, in order to sell you replacemants,,,,
Mar 30, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
I need to know the ohm rating for the speaker in a
Judging from the "10D", that most likely means 10 watts. 6.5 inch speaker, probably 8 ohms. Most amps of this nature have 8-Ohm speakers.
Their 12-watt and 15 watt amp have a 6.5". Their 20 watt amp has an 8". The 80 watt has a 12".
Hope this helps.
Mar 28, 2010 | Peavey Pv 2600 Power Amplifier
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
247 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
