Question about Connex 3300 240-Channels Base CB Radio
Disable talkback cannot disable talkback in this radio.
    Novelist:
  • Connex Expert
  • 500 Answers
One turn off echo and talkback will turn off. or disconnect the wire goin to the transistor off the echo board that turns on the talkback.
Posted on Dec 04, 2009
How do I turn off the talk back feature on lg tribute
TalkBack won't turn off - Google Product Forums
productforums.google.com/d/topic/nexus/av7djMHBA14
Google
Oct 23, 2013 - 100+ posts - ‎100+ authors
Re: TalkBack won't turn off, Nexus 5 -curious user, 2/15/14 6:38 AM ... I don't blame Google for making this feature so difficult to shut off once ...
How to Disable Talk Back Mode? « Android Gadget Hacks
android.wonderhowto.com/forum/disable-talk-back-mode-0147617/
Jun 24, 2013 - If you just have the regular swipe to unlock feature for your lock screen, to unlock it ... Now, to disable TalkBack mode, you need to make your way to ... I only turned on because my lady friend has an LG Stylo G and she set her ...
How to Exit 0r Disable "TalkBack" Mode on LG Optimus F6 ...
? 3:11
https://www.youtube.com/watch?v=YDmcLi9kF8w
Dec 3, 2014 - Uploaded by Klavdio-Leadership
This Video will show you how to disable the TalkBack Mode on your phone.
LG L70 how to Turn off the talkback or voice over - YouTube
? 2:29
https://www.youtube.com/watch?v=FEei11i4OGg
Jan 13, 2016 | LG Tribute 4G No-Contract Cell Phone
HOW TO UNLOCK SCREEN
To Disable TalkBack mode
  1. 1 Go to the home screen of your Samsung Galaxy S3 S4 or Note2. Was this step helpful? Yes ' No ' I need help
  2. 2 Now, go to settings, menu option. There is an invisible button to the left of your home button. Press that button, and select Settings. While in TalkBack mode you will have to double tap to select menu items. So double tap settings. Was this step helpful? Yes ' No ' I need help
  3. 3 Now select accessibility. Share this Share this on FacebookTweetPlusPinShareRedditDigg settings-accesibility.png While in TalkBack mode you have to use two fingers to scroll / swipe to get down to the accessibility menu item. Again, you will need to double tap to select accessibility because you are in TalkBack mode. Was this step helpful? Yes ' No ' I need help
  4. 4 In accessibility you can now disable TalkBack mode. Share this Share this on FacebookTweetPlusPinShareRedditDigg accesibility_-_talkback.png There is also an option here to disable "Text To Speech," which you must also disable. You can disable it here or an alternate method is covered in the next section. You can use either method. If you have trouble with one method, try the other.
May 23, 2014 | Samsung SGH Cell Phones
How do I disable talkback on my cobra 29 ltd radio
check to see if its hook to the speaker jack. if it is just clip the resister. if its hooked to a dial then you are in hot water. follow the wires from those variables to see where they go . when you find the right one clip it.,no more talk back.
Jan 13, 2013 | Cobra 29 LTD CHR CB Radio Chrome Special...
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Talkback
If no switch for this on the radio have a shop look to see if can place one or disable that feature.
Nov 05, 2012 | Cherokee CBS2100 40-Channels Base CB Radio
My tr966 has talkback hooked up on it and would like to disconnect it on the board?
Your gonna look in your radio by the transformer for a"d25" diode 25 is what is removed in this radio to add talkback. If you want to disable talkback you need to replace that diode as this radio is not stock with talkback. Someone removed that diode. Diodes only go in one way. Pay attention to the cathode marking on the board and on the diode ( --> ) no smaller than a 1N914 diode as a replacement.
Mar 20, 2011 | Ranger TR-966 CB Radio
Talkback sqeels when it decides to work!
the squealing you are referring to is usually due to to a disabled automatic modulation control circuit.
one or more dry solder connections could cause the intermittent operation.
May 22, 2009 | Galaxy Radios DX-95T Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
http://www.cbtricks.com/radios/cobra/150gtl_dx/tsb/cobra_200gtl_dx_tsb_10041.pdf
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at rollincbmods@yahoo.com. I look forward to hearing from you.
Dean
Rollin CBs
Mt. Vernon, TX
Feb 13, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
530 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
