Question about Ruud UAMB Air Conditioner
Ruud gas pack has stopped heating.
It starts to come on, but only blows cool air, and after only about a minute, it quits blowing anything and stops. It was fine last evening, but the house was 60 degrees this morning at wake-up time. I cut the thermostat off, then back on, but nothing. After the third try, it came on but would cut back off almost immediately. I tried this for several times, then it finally started blowing air, but cool and only for a minute or so before it cut itself off altogether. I just had it serviced, and all the jets were blowing straight ahead, which tells me it would not be a cracked heat exchanger, right? What does it sound like to you guys? Roll out switch, thermostat, ??? Thermostat says system on but furnance does not work. No fan on and no flame. RUUD Gas Pack.
    Problem Solver:
  • 7 Answers
Could be a faulty thermostat, (referring to the furnace\heater. As far as the A.C., you must have a dual thermostat with a switch for A.C. and Heating. Is the thermostat digital or mercury bulb? As for the A.C. it sounds like it is going off on high discharge pressure. Is the cooling fan running that cools the condenser? It must be spinning freely or it may be starting and because it is partially seized, it will cut off with a high current draw. Anyways, the condenser must be clear of any debris, no shrubs around it. The compressor could be bad and trying to start but goes off on overload because it isn't starting. It's start capacitor could be bad and not giving it that extra boost on start up which is what a start capacitor does. Good luck.
Posted on May 31, 2009
  • Ken Beccu May 31, 2009
    I had a similar problem with a combination A.C.\Furnace. The igniter checked out O.K. but the solenoid which opens the gas valve failed and the furnace start fails after a short time and goes off. The valve is all one component and should be changed by a professional so as not to have any leaks of N.G. which will be problematic. I assume the unit is on the roof. Go up on the roof and pull the disconnect. Then activate the thermostat to heat and raise the temp to say 85 to keep the system calling for heating. Then go back up and close the disconnect and watch to see if the igniter is sparking. Maybe the gas valve is stuck and you can tap it with something to dislodge what ever is blocking it. Just a thought. The igniter will only spark for a short time until the system doesn't see any flame\heat. Then it will disengage. Good luck.
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Heating unit blows warm air then turns to cold air
it sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Jan 11, 2010 | Ruud UBHC Air Conditioner
Hi i have a whirpool gas dryer that all works fine but after about five minutes the heat will stop and it will just blow cool air. I can stop it and restart and everything starts and works fine and after...
The gas valve coils are closing the valve or the flame sensor is defective. The coils are the most common problem.
There are 2 on top of the gas valve. Turn off the gas and power. Remove the front panel by opening the top lid and then remove the screws from inside the front panel in the top right and left corners.
Nov 09, 2009 | Whirlpool Dryers
Ruud Achiever 90 plus not blowing air
the motor is bad or start capicitor
Aug 29, 2009 | Heating & Cooling
Is it spark ignition or a glow coil? Sounds like the ignitor is busted. If it was a roll out switch the fan would stay on trying to cool off the switch.
Feb 24, 2009 | Ruud UAMB Air Conditioner
Ruud UAMB Air Conditioner Logo
240 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
