Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Panasonic projection TV power blinks in orange 5 times every 5 seconds
I have a panasonic PT-50LC13 rear projection LCD TV. It used to work fine. Then when I press power button,  the power indicator starts from green then to orange and blinks in orange 5 times every 5 seconds. Anybody have any idea how to fix this? No fan is blowing. Seems like there is no power into the lamp. Could this be a ballast issue or a fuse issue. I tried to open the back and check the fuse. It's hidden inside a ic board and very hard to pull out and reach it.
Any help would be appreciated.
  • 5 more comments
  • pfan Oct 23, 2007
    the lamp is not busted. Should be ok. Not sure where is the ballast ans how to check it.
  • fabulous Nov 04, 2007
    Model Number Panasonic PT-50LC13. The power light blinks orange and never changed to green. Any solutions?
  • Anonymous Nov 16, 2007
    I have the same problem with pt50lc13. I don't know what to do. The TV was out of warranty.
  • jalli Dec 16, 2007
    yes I do. The green light keeps bliking. Checked the lamp and found to be all right. How to chek the fuse or ballast and what instuments needed to check those. Any help appreciated.
  • terib1016 Nov 18, 2008
    how do I check the ballast? i checked the bulb it looks fine. One other thing, the fan is not comming on. The only light flashing is the lamp light. I never reset it awhen i replaced the bulb a year ago. Did not know you were suppose to, the repair man did not tell me this. Can't reset now as the tv just blinks from green to red.
  • Anonymous Mar 26, 2014
    It was playing fine and just shut off. and the blinking started. 9 blinks followed by 5 blinks
    TV was playing fine and just shut off. Power light started blinking 9 blinks followed by 5 blinks
  • 59 Answers
Did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Posted on Oct 23, 2007
  • tvray Oct 24, 2007
    follow the lamp plug to the ballast there will be a two wire connection on the ballast ck voltage there
I have a Panasonic Model PT-50LC13 flat TV. Was working when got it brought it home, it is used and now when I go to turn it on --- we get a green light then a flash of 5 yellows blinks then no light for...
This tv has 3 indicator lights on front, Power, Lamp and Temp
I assume Temp light is blinking 5 times after every 5 seconds, if that is correct then it is problem of clogged air filter located in light engine that need to be cleaned.
Below is an image of light engine and air filters locations are marked with red circle, it is job of professional to fix this issue because complete light engine need to be take out from tv cabinet.
Hope these info will help you, let me know if you have additional question or need service manual copy if you want to repair tv by yourself.
Nov 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PanasonicPT-50LC13 blink codes
pretty sure this is a problem with one of the cooling fans.
Jul 12, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic 50" LCD TV PT-50LC13 and the power botton blinks orange 2 time and there is no pic but i can here the fn runing what can i do???
if the tv keps trying to turn on three times and later the lamp led stays steady red. (see owner's manual to replace the lamp process) the lamp is damaged. ones you open the lamp door and take the lamp out you can see the lamp damaged even before to buy it.
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
Aug 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
800 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
