Question about Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop good spark.
  • 376 Answers
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Posted on May 31, 2009
Starting manual for mantis
all of the mantis tiller manuals can be found here:
http://mantis.com/mantis-owners-manuals.asp
just pick out the appropriate one and away you go.
as far as starting it goes, make sure the switch is set to "I" and not "O" (top handle.) be sure you have gas in it, pull out the choke knob (front of the tiller) and depress the bubble once. pull the engine cord until the machine tries to start, then push in the choke and pull again - the engine should start within a couple of pulls. let it warm up before you try to do any tilling, and you're good to go!
Sep 12, 2012 | Mantis Gas Mini Tillercultivator 2cycle...
My mantis tiller 2cycle: Iput new spark plug the on&off switch ok just not getting a spark to the plug. Think its the coil ?
I would say it is the coil, if you have a multimeter you can connect it to the coil and try to start it to see if it producing voltage. Hope this helps Tim
Apr 16, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I have a manis tiller that wii not run rigth. i have put i a carber kit
My mantis tiller ran fine,I put it up for the winter and now it won't start,I checked to see if it was getting gas which it was, could it be the coil? I did check and they say its very rare that the coil goes out.I also check for any type of spark and nothing. Please help!!!! thanks ,Clay
Mar 26, 2011 | Mantis Gas Mini Tillercultivator 2cycle...
Yesterday it quit running after performing normally for about an hour. Now I cannot get it started. Motor turns over easily, but won't fire.
If you have the 2-cycle Mantis tiller, it uses the ECHO engine. ECHO warrants the ignition coil for life to the original purchaser. If you have VERIFIED there is no spark at the plug, grab you reciept and head for your local ECHO dealership. If you aren't sure where one is and need to locate a Servicing Dealer, click HERE.
Hope this is helpful,
Dolf-
Oct 20, 2009 | Mantis Tiller
Mathis tiller sv-4 engine no spark form coil
clean and adjust the ignition points.
Jun 19, 2009 | Mantis 2-Cycle Tiller
What is left to do but change the flywheel?
check what they call air gap between the coil and flywheel .010-.012 gap
also be sure your flywheel is in time.
you will actually have to remove it to do this and check for the sheared key or be sure the key way aligns with the crankshaft keyway on the flywheel
May 17, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
843 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
