Does not agitate
I have an 18 year old whirlpool top load washing machine. it fills and drains ok but does not agitate. drums spins fine during spin cycle. model number is LA5578XTWO
  • 10,865 Answers
Agitation is the most complex operation in any washing machine. There are several components working together to make it agitate and as a result it is a challenge to isolate the problem or problems involved. Here is what to look for:
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 31, 2009
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Pump works. Spins when empty/no load in tub. clutch slips when loaded
If the drive belt is slipping during the agitate and both spin cycles for loaded conditions, I suspect that the drive belt is excessively worn. If it slipped only during a loaded spin cycle, I would have suspected that the sliding motor mount is gummed up and not moving to a belt tighten position during the start of a spin cycle. Since the unit drains with no problem for loaded and unloaded conditions, the pump belt should be OK. Replace the drive belt and clean the dust, gunk, detergent, etc, out of the sliding mount to make sure that it tightens properly when a loaded spin cycle starts. Note that on most models, the drive belt is designed to slip when spin cycles first engage, and they will continue to slip until after the drum has accelerated.
Sep 23, 2009 | Whirlpool LSR5132PQ Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
