Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
Polaris in pool cleaner back water single spout not water passing
Wheels will not move plent of water going through the other side with 2 spouts and rear spout vaccum working but no wheel rotation brand new cleaner purchased last year!
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    is the small wheel between the two tires moving?
  • 640 Answers
Check your wheel RPM. With these automatic pool cleaners, you can manually adjust the RPM. Low RPM could be the cause of the problem. To check the RPM, first mark a single wheel side tire, Turn the pump on, hold the cleaner under water and count the wheel revolutions for one minute. If the RPM is less than 28, you might need to remove the blue restrictor disk from the UWF or adjust the gate valve on the booster pump. Also, this may sound simple, but make sure there is no debris lodged in the wheels/axles. Check your filter screen in your in-line filter and make sure that it is clear of debris. You will also want to check your hoses, connections, and swivel to make sure that there are no leaks.
Posted on Jul 21, 2010
My polaris is doing circles. it appears the single wheel doesnt move like it used to
i've just discovered i have this same issue with my polaris 3900. the machine is less than 3 months old. there is a small metal "gear" in the wheel hub just behind the blue "hub cap". a single screw holds it on the axle. it appears that the gear has worn the out around the hub causing it to slip and not be able to drive the wheel.. it appears that the solution would be to buy another wheel.
Dec 31, 2010 | Polaris 3900 Sport Pool Cleaner ()
My polaris 3900 moves across the pool with the front wheel of the bottom, the wheel on the 1 wheel side and the back wheel are on the bottom.
Check your wheel RPM. If the pool cleaners RPM is over 32, reduce the water flow so that the cleaner makes proper contact with the pool's surface. Verify the back-up valve is cycling. Lift the valve out of
the water and watch the jet. It should come on and go off. You might also need to adjust your thrust jet if it is causing the cleaner to lean too far to one side.
Oct 11, 2010 | Polaris 3900 Sport Pool Cleaner ()
My Polaris 3900 Sport Pool Cleaner's doing tight circles in the pool because the single left-side wheel is not turning at all, while the 2 right wheels are turning normally. How do I fix it?
I had a similar issue. When I lifted the unit out of the water while it was operating only the single wheel was rotating. I turned it off and removed the bag and hose. I flipped it over on a workbench and unscrewed the three recessing screws securing the base plate. Once the plate was removed I noticed the metal chain driving the two wheels had come off on the far side of the inner sprocket. I worked the chain back onto the sprocket and tested it by rotating the single wheel and verifying the other two wheels rotated. After reassembly I put the unit back in the pool and it drove straight and high on the sides. Hope this helps someone :-)
Aug 21, 2010 | Polaris 3900 Sport Pool Cleaner ()
Polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
Jul 21, 2009 | Polaris 380 In Ground Pool Cleaner
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
223 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
