Question about HP OfficeJet G85 All-In-One InkJet Printer
Remove and Check Color Cartridge message
My status window shows "remove and check color cartridge".  I've done that, cleaned everything and turned the printer off and on.  The message will not go away.
  • 1 more comment
  • Anonymous Nov 08, 2007
    my status window shows "remove and check color cartridge". I've done that, cleaned everything and turned the printer off and on. The message will not go away
  • raffles Nov 14, 2007
    Same problem as others says "remove and check colour cartridge" I've done that several times, turned the computer off at the power point etc. Help please!
  • Anonymous Jan 07, 2009
    Yes, i have the same problem
Just had the same problem on my G85. Did the cleaning of color contacts, the powering on and off, and the cleaning and aligning of heads to no avail. Last resort went to HP website (why is that always last resort?) and saw that sometimes the circuits confuse color and black cartridge problems. Cleaned black cartridge - problem cleared. Coincidence? Maybe. But maybe not.
Posted on Jan 29, 2008
This also happend to me and the thing almost got office spaced out in a field,but i have the answer.
All you have to do when it gives you that check cartridge message is go ahead and hit black like a normal copy it may say busy thats fine the message will not go away just yet and copier will look unresponsive but it just takes like 5-10 min but will eventualy fix its self the copy will spit out and every thing will go back to normal,so dont cancel or turn off power patience grass hoppa it will be ok i promise
Posted on Aug 04, 2010
It must have been a software glitch because it fixed itself
Posted on Nov 01, 2007
HP Photosmart C4140 error message won't go away Remove and check color cartridge. I have done this and unplugged, checked both color and black cartridges...won't go away.
hey, sometimes there are faulty cartridges. i use to got some brand new and original from the shop and not working.. so try it with some old cartridge if you have.. you can also try to remove the cartridge and clean/wipe the contacts on the cartridge side and on the printer side (turn of the printer for safety)
Sep 18, 2011 | HP Officejet 5510 All-In-One Thermal...
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 03, 2011 | HP Office Equipment & Supplies
I got a message "Remove and check color
you can try to remove and clean the chip contacts of the cartridge and or the cartridge housing. if it still doesnt work try resetting the printer ink counter.
Feb 28, 2011 | HP PSC 1610 All-in-One Printer, Scanner,...
It's circuits may have failed. Try replacing the cartridge.
Mar 18, 2010 | HP Photosmart C4150 All-In-One InkJet...
Message says Remove and check color cartridge. We
The cartridge cavity in the printer may need cleaning.... perhaps a colorful "spit wad" is lodged in the cavity.
If the printer will allow, run a "clean nozzle" utility from the printer or computer.
Hope this helps!
Sep 08, 2009 | HP Officejet 7210 All-In-One InkJet...
HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Apr 14, 2009 | HP Deskjet 6940 InkJet Printer
Sounds like the contacts are dirty. A cotton swab and some rubbing alcohol might help.
Sep 19, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
    Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
    HP OfficeJet G85 All-In-One InkJet Printer Logo
    584 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
