Question about Linksys WRT350N Wireless Router
Secondary computer will not connect wirelessly; IP address problems.
I just hooked up a Linksys WRT320N and I'm doing fine w/ my house desktop. My iPhone also connects fine but my mac mini in the back of the house can "see" the network but not connect. It seems like the IP address is the problem. I tried to fix the IP address by making one a static address on the router site but I'm pretty sure I just made the problem worse. Help? I have the same problem. I have 2 computers trying to connect to my new WRT320N wireless router and they see the internet but cannot connect to the internet because the router is not assigning an IP address to each comptuer. They show the signal is good/ great and they just sit trying to connect. I need a solution also.
  • hyder_j May 31, 2009
    The router works fine when the Ethernet cable is driectly plugged into the router. And all of my wireless computers can see the internet/ wireless signal, they just cannot connect to the internet because the router is not assigning IP addresses to the computers.
  • ikkenom May 11, 2010
    Connect a computer with an Ethernet cable directly to the router.
    Follow the instructions in the manual that came with the router to connect to the web-interface "inside" the router.
    The router should display a list of "connected" (wired and/or wireless) computers. The router may even have a "wizard" to help you correctly setup your wireless network.
  • 86 Answers
If the router is not assigning an IP then you are probably not actually connecting to the network. Try disabling your wireless security on the router and see if they connect. If they do then you know the problem lies in that direction.
Posted on Jun 03, 2009
My wireless router is connected to the internet, but when i connect my computer wirelessly, it does not give an internet connection
Does the router let you connect to the internet if you plug into an ethernet port? Are you trying to use the wireless network while you are also plugged into the ethernet? If so, unplug the ethernet and try again.
Open a command window and type 'IPCONFIG /ALL' if you can see the IP address of your wireless connection, is this in the range 192.168.n.n (for example 192.168.0.3)? Can you see if the GATEWAY IP address is similar to that, such as 192.168.0.1?
Open a browser window and type the gateway IP address into the address bar. Can you connect to the router? (It will probably ask you for a userid and password)
Jul 26, 2011 | Linksys WRT320N Wireless Kit
WRT320N WIRELESS ROUT i GET ADDRESS CONFLICT ERROR MESSAGE
state how many computers you have connected to your router, also what operating system they are running. Two computers or devices have the same IP address hence your error. Ensure they are all getting there IP via DNS and not manually
Feb 25, 2011 | Cisco Linksys Wirelessn Router Black...
When I try to connect to the wireless of the linksys wrt320n, I am prompted to enter the device password? Where I could find this device password?
Hi tabua/rob,
When you try to connect to your wireless network, you will be prompted for the password. Please note that this password is to authenticate you to connect to your wireless network. You need to log into the router from a computer which is connected to the router with an ethernet cable to find this password from the router's web interface.
1. From the hardwired computer (If you don't have one, you may have to connect your computer to the WRT320N with an ethernet cable on one of the 4 ethernet ports).
2. The default ip address of linksys routers is 192.168.1.1. You could access the router's setup page by typing http://192.168.1.1 in your web browser.
3. Please leave username blank. Enter "admin" in the password field (But without quotes)
4. You should be logged into the router's setup page.
5. Click on the "Wireless" tab. You may find "Wireless Security" just below it. Click on it.
6. You should be able to find your wireless password here. If you are using WPA security, then you need to note down the "Pre-shared key" value from this page. If you are using WEP security, then you have to note down "Key 1" value. This will be your password for your wireless network.
7. Then try to connect to your wireless network from your wireless computer. Enter the password, which you have noted in step 6, when prompted. WRT320N should recognize you and allow you to connect wirelessly, provided the password is correct.
I hope this helps you. Kindly rate my solution, if it does.
Thanks
Dec 12, 2010 | Linksys Computers & Internet
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Can not connect to internet with the wrt320n but can with wrt54g
check the ip address, subnet mask, default gateway of the server computer then fill it up to ur comp same as the derver comp except the ip address change the ip address then try.
Oct 22, 2009 | Linksys WRT350N Wireless Router
No internet connection to secondary computer in house
check the ip address, check if the ip address on the 2nd computer is the same with your linksys.. check also the cables, u will notice the cable attached to the computer that it will blink.. make sure that it will blink like orange color.. check connectivity.. physical connection first
Sep 24, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Signals
Do you have a wireless adapter installed on your win 2000 computer?
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT350N Wireless Router Logo
266 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
