Question about HP Computers & Internet
Floppy drive not listed in computer mgmt
My floppy drive is enabled in the bios appears in the device manager, the drivers also no yellow question marks BUT does not appear on the list in computer mgmt.i also get a message like this every time i put a disk that contains data in the drive: the disk in drive A is not formatted would you like to format now? needless to say my floppy drive does not work and it is new.
    Novelist:
  • 152 Answers
Your floppy disk drive has failed. You will need to replace it. they are usually pretty cheap.
Posted on May 31, 2009
How to enable usb port LG 22LD330
On the desktop, right click on MY COMPUTER, and then select MANAGE option. a new window will appear, in that select SYSTEM TOOLS, in that click on DEVICE MANAGER, on the right side of the window pane, a list wil appear,
If USB is enabled in BIOS or EFI but the USB host controller does not appear in Device Manager (under Universal Serial Bus controllers), or a yellow warning icon appears next to the host controller name, then the version of BIOS or EFI may be outdated. Contact the maker or vendor for your computer and obtain the current version of BIOS or EFI.
If the controller appears in Device Manager, right-click the controller name and then click Properties. Problems and suggested actions are displayed under Device status.
USB ports have a separate entry in Device Manager. To check the device status, click Universal Serial Bus controllers, right-click USB Root Hub, and then click Properties. If you do not see USB Root Hub, you might not have a USB port installed on your computer
On the USB Root hub Properties page, it may tell you this device is working properly, or there is a Troubleshoot button. At the bottom you have an option to Enable or Disable the USB hub.
Jan 22, 2014 | LG Computers & Internet
External floppy drive does not work on this pc but on others
Hello!!!
You have to install the drivers which has come with the external floppy disk!!!
Jul 31, 2008 | Mitsumi (11-08004) (1108004) External...
Tip
Vista to XP
1st to do is The Bios Configuration Settings.<br /><br />Options include... disabling "Native SATA Support" (or enabling IDE emulation) in the BIOS which allows you to install and run XP without the SATA drivers..<br />or<br />Using a USB floppy drive to install the CORRECT SATA drivers during the XP install.<br />or<br />Finding and slipstreaming the CORRECT SATA drivers for your specific laptop.. The correct XP driver information for computer can be gleaned by writing down the appropriate Vista Device Manager listings BEFORE formatting the computer.
on Nov 13, 2010 | Computers & Internet
TDK fdd-100 external floppy drive won't mount
check the leads that attach this external floppy drive make sure they have a good secure connection
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps you
Oct 31, 2011 | TDK External USB Floppy Drive FDD-100AX...
It does not recognize USB
Make sure that the driver for the USB is installed f your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices
Sep 01, 2011 | HP Compaq nc6000 Notebook
Starting BIOS recovery... Checking for floppy... Floppy not found checking for cd rom reading k8v-mx.rom not found How to solve this problem
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
May 05, 2011 | ASUS K8V-MX Motherboard
I have installed a new floppy hard drive but my pc does not recognise it. how do i activate it? and why is the green light always on even without a floppy inside it?
Get into your bios and enable the "A" drive in the bios if you haven't already. It has to show up in the bios for it to show up in the device manager in windows. Start at the bios and work up to the device manager and reinstall floppy drivers if needed.
Oct 14, 2009 | Computers & Internet
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My stem not recognising floppy drive.
IF IT HAS DETECTED THE DRIVE IT MEANS THAT SYSTEM IS RECOGNIZING THE DRIVE, CHECH THE DRIVE STATUS ON DEVICE MANAGER, ALSO TRY TO ENABLE IT FROM BIOS (PRESS ENTER KEY ON IT, OR +/- KEY TO CHANGE IT) AND RESTART SYSTEM.
Nov 25, 2008 | Televison & Video
Computers & Internet Logo
116 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
