Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
Cleaning the cast iron grates and griddle
I just got the gas oven. it has cast iron grates and griddle. how do you clean them. when i use a rug and soap the fibers from the rag stay on the griddle. what do i use to clean it. I have the same problem with the cooking stains on the griddle. I am conerned that if I put in the oven during the self cleaning cycle, the rubber "feet" on the griddle will be destroyed. Can I use steel wool to clean it?
  • 10,865 Answers
Here is the best method. Melt a tablespoon of vegetable shortening, such as crisco in a small pan, then add a table spoon of salt. Mix this up and let it cool enough to handle it. Using a cloth or a paper towel apply this mixture to your cast iron and scrub then rinse in hot water, adding a little liquid dish detergent to thoroughly remove the salt mixture. I do not like steel wool because it leaves a residue of tiny wool particles on the surface. AND do not put the griddle in the oven to clean it as it will melt the rubber feet.
Posted on May 31, 2009
  • 1,305 Answers
Take the grates off and slide them on your dishwasher rack and run them thru a cycle... pull them out before dry if you want..
    Habit-Forming:
    Scholar:
  • 130 Answers
You should not use soapy water or wire scrubber for cleaning of cast iron cookware such as grates and griddle. It is best to use paper towel for good care of these cookwares, you can use hot water to loose the food stuck on the pan.
Get more details here: GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Posted on Jul 30, 2015
Have cast iron grates with no enamel on them. Burned on grease, etc on grates from previous owner. Can I clean them in a self cleaning oven? If not, what is best way to clean? Thankyou.
I would spray them down with a good oven cleaner ,outdoors and let them sit there soaking a couple days . then wash off and see what they look like .
Apr 15, 2015 | Jenn-Air JGD8130 Gas Cooktop
My Bar B Chef grill grates are totally rusted. Are stainless steel grates better or should I stick with cast iron?
I prefer cast iron. Cast iron heats more evenly and retains temperature better. If they are falling apart from rust, junk them. If they just have surface rust and no holes, all you have to do is brush them with a steel brush at high heat. Wipe them off with a wet rag and then rub it with an onion to provide a teflon layer. if it is really heavy rust, spray oven cleaner on them and hose off. After use or for storage, clean them and then wipe them down with a cooking oil soaked rag. The oil will reduce rust build up.
Feb 28, 2015 | Grilling
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Which is best porcelain or cast iron grates? I am
Cast Iron by far, ceramic grates chip and are VERY difficult to clean!!!
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Cleaning surface grates on 10 year old Jenn-air Gas-electric
Spray them w/ oven cleaner, put them in a plastic trash bag, and let them sit overnight. They should clean up w/ minimal scrubbig.
Sep 18, 2009 | Jenn-Air Kitchen Ranges
Cast iron grey grates are hard to clean
Don't use oven cleaner! It isn't recommended by GE. Their book explicitly says to put the grates in a plastic garbage bag and pour a some ammonia into the bag. Tie the bag tightly so all the gas stays inside. Put in a garage in case it leaks because it can smell bad. Wait 24 hours and the stains will come off with a hose and some light rubbing. I didn't believe it at first but it works great! My wife loves our 'like new' oven.
Sep 09, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Cleaning the stainless steel griddle??
We buy DeBruce Polish at debruce polish.com this stuff really works!!
Mar 28, 2009 | Thermador Professional Series PO301...
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
Try This....
Place the grates in a sink of hot, soapy water and let soak for 15-20 minutes. For tougher stains, add a cup of sudsy ammonia to the water. Make sure grates are thoroughly dried after each cleaning. After the cleaning process, Lightly coat the bottom of the grates with a cooking spray and then blotting them dry.
Or
If you self clean the oven on occasion, put them in the oven when running the self clean cycle.
Jun 22, 2008 | Frigidaire 30" Self-Cleaning Slide-In Gas...
How to clean electric griddle
Hi there!
When it is warm, use a spray cleaner and paper towel to wipe up the grease.
Wooden or non-stick spatulas make excellent scraping tools to take the worst off first.
Use paper towel to wipe up.
For really stubborn deposits, use an oven cleaner - and cover with plastic film. Check in 1 hour, and clean as above.
Soda Crystals dissolved in hot water are excellent at cutting through grease, but may affect aluminium. They work out cheaper than many commercial products.
Hope this helps you.
Jun 01, 2008 | Kitchen Appliances - Others
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
1,809 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
