Question about Kodak EasyShare Z740 Digital Camera
Have Kodak easyshare Z740 camera, turn on and goes right back off. Battery seems to be fine tried several charged batteries. Mine does the same thing as well
  • 2,335 Answers
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Posted on May 01, 2010
    President:
  • 2,761 Answers
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Posted on Aug 16, 2009
Kodak easyshare Z740 battery problem
I hope that helps.
Oct 22, 2009 | Kodak EasyShare Z740 Digital Camera
Bought a kodak easy share z740 camera I love it very much but it just stopped working and I paid over 400.00 for it can I get it fixed or replaced
Won't turn on at all, or shuts off after a few seconds? This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. if charging/replacing the batteries doesn't clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
Jun 24, 2009 | Kodak EasyShare Z740 Digital Camera
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
May 13, 2009 | Kodak EasyShare Z740 Digital Camera
Camera won't stay on
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
May 11, 2009 | Kodak EasyShare Z740 Digital Camera
Z740 switching off - new batteries not making any difference
I hope that helps.
Apr 30, 2009 | Kodak EasyShare Z740 Digital Camera
My camera all of a sudden attempts to come on and then cuts off.
I hope that helps.
Mar 30, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak Z740
I hope that helps.
Jan 03, 2009 | Kodak EasyShare Z740 Digital Camera
Camera goes off
I hope that helps.
Oct 15, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Won't turn on after changing batteries
I hope that helps.
Feb 29, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
149 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
