Question about Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
  • 57 Answers
Yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
Posted on May 31, 2009
Why when playing my dvds the screen turns blue and says screen disabled for your safety?
Your parking brake wire is either not correctly installed or your parking brake is not engaged. It is illegal to drive while watching video so the player will disable video if you are not parked.
Jul 12, 2012 | Pyle PLDN73I Car Video Player
How do i bypass parking brake wire? do i connect to negative or
what color is the wire from the radio it might be pink or purple with white strip. but the wire needs to see ground or parking brake wire
Mar 07, 2010 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Parking brake disable model jensen 9511ts
on the jensens, there is a way to disable the parking brake without having to put a switch on the parking brake wire. the catch is that you will need the remote control to get into the service menu. follow these steps
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
if for any reason yours doesnt offer this option. you can always put a switch on the ebrake wire of the screen.
1. use a 2 wire toggle and wire one side the ground and the other to the parking brake wire on the jensen. then do the pattern on the switch instead of using your ebrake.
Aug 28, 2009 | Jensen Car Audio & Video
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Jan 30, 2009 | Jensen VM9411 Car Video Player
Place the pink wire to a ground. Hope this works for you.
Jun 01, 2008 | Jensen VM9410 Car DVD Player
Linear uv7
here's the code. I did this with my remote and it works.
press stop twice(which is also the band button)
press1,2,6,4
press down 1 time(button below the play/enter)
press play/enter 1 time
(you should see the menu now)
brake override should say no
I was told to change macrovision to no
hit system setup twice to save and exit
hope it works like mine did
Dec 07, 2007 | Phase Linear 160W AM/FM/CD Receiver W/...
How do i bypass the parking brake switch in order for my video to play
isn\'t there a way to bypass the parking brake so my video plays anytime i want
Dec 15, 2006 | Jensen VM9510 Car DVD Player
Jensen VM9410 problem
two things might be wrong is there 12 volts and is there a good ground . hope this might help.
Jan 03, 2006 | Jensen VM9410 Car DVD Player
Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player Logo
751 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
