Question about Samsung 4 Channel Dvr
Search I am unable to playback anything I record, I get "NO DATA" on the screen. The drive shows full at 160 GB, but I can not search the data.
Having the same problem. Just spoke to samsung [1-800-samsung] They told me to reboot and if it doesn't solve the problem would have to replace the hard drive. They said press mode, 4 and zoom all at the same time and hold for 12 seconds to reboot entire system. Use buttons on unit not remote. Didn't help mine, good luck with yours.
Posted on Feb 12, 2008
Screen shows nodata
Screen shows "no data found". ' Relias Connect
https://rlconnect.reliaslearning.com/thread/4943
Screen shows "no data found". 2153112 Sep 2, 2015 8:53 AM. Screen shows "no data found". 20 Views; Categories: Senior Care - Assisted Living, Home Health ...
Charter.net No Data Message on a Gray Screen
www.charter.net/support/tv/no-data-gray-screen/
Charter CommunicationsTV with grey screen displaying words - No Data. If you are seeing the words "No Data" on a gray screen on your TV, follow these troubleshooting steps.
Why does screen shows NO DATA even after tracks have ...
https://sony-paa-pa-en-web--paa.custhelp.com/.../why-does-screen-shows...
If the unit holds no data transferred from SonicStage, the screen shows NO DATA. User can playback the tracks recorded with the unit from HOME screen - Rec ...
Feb 09, 2016 | Televison & Video
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
Hp v250w 32 gb pendrive problem
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
hope this helps
Sep 12, 2012 | Computers & Internet
I can't download any data more than 1 GB. Always showing that phone memmory is full. Please delete some data from phone memmory. But I have enough free space in extended memory. 12 Gb is free.
Morning there
It may depend on what kind of material you are downloading, I have had similar experience. For me it worked to devide the material into smaller units, to download inparts. I do notknow if that will work for the material you have. Give it a try.
all the best
Kolbrun.
Feb 20, 2012 | Nokia E7 (16 GB) Smartphone
The Samsung HM160HC 160 GB IDE Hard Drive that i am using is making a clicking noise whenever it is plugged into the computer. The computer also cannot read / recognise the disk. What can i do to recover...
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
Otherwise, you have already tried all the 'Do-It-Yourself' options.
Oct 22, 2010 | Samsung HM160HC 160 GB IDE Hard Drive
After copying into pendrive files are damaging and corrupting and also showing okb of every file what is problem and show me to how to recover from that it is new pen drive
download a data recovery program and use the program to scan the pend drive and recover lost files. I used a file recovery program called asoftech data recovery before, quite easy to use and works well for me, you may download and have a try.
http://www.asoftech.com/adr/
Sep 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
External imation hard drive showing an empty folder !
You can run a data recovery app on the drive and attempt to pull offany data still accessible. I recommend the GetDataBack Data Recoveryapps from http://www.runtime.org . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Aug 24, 2009 | Western Digital My Book Essential Edition...
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
Getting message "pls insert disk in drive" on inserting the USB
Hello sir/Madam,
You can recover by doing the following:
go to transcend website and download this software;
(http://www.transcendusa.com/products/online_recovery.asp) and then you have to select repair and save data..
andthen also if you dont get ur full data,you can download Pen driverecovery from many sites(search on google) and recover or else email meat devgolani@gmail.com for full software..
Regards
Devesh Golani
devgolani@gmail.com
http://www.lifeproblems.uni.cc/blogs
Mar 10, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Playback on Samsung SHR-1040
you need a new hard drive.
Aug 27, 2007 | Samsung 4 Channel Dvr
Samsung 4 Channel Dvr Logo
138 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
