Question about HP Pavilion a6600f Desktop PC
Power failure for HP Pavilion A6600F
Machine refuses to boot, when power button is depressed there is no response. LED on power supply indicates PC is receiving power and all other electrical items, EG: monitor, work fine. Running XP home, SP3 I have seen similar problems with other machines. My friend has this pre-built system designed by HP (model Pavilion a6600f) I presume all components are origional and/or specific for that model. Power box indicates its getting proper power and there are no problems with my room's electrical outlets. Somehow, my friend manage to spill a significant amount of water on his computer just before he dropped it off at my house. The casing of the computer has large ventulation holes on the side - an ounce or so of water had gotten on the motherboard and respective components. I left the computer off for about eight hours - hoping that would be enough time to dry off the system. (I had a computer that was internally covered with condensation buildup of ice vapor - which melted into water when I brought it into my house, I let that computer dry for about the same time and had no problems.) I've checked all the wiring and found no error. I've reduced the amount of components the power box was supplying - down to the motherboard. I've removed all external connections, reset the bios, reset the bios password manually. I've checked to see if the system would run without the ram - no effect. I've manually tried starting the system using a metal screw-driver to no effect. If it comes down to it - I might have to test an alternative power supply to rule out the existing power supply. There's no obvious detail of a previous power conflict resulting in burnt capacitors or significant other. (I've had that happen to one of my computers several years ago.) If I was more curious I'd take the board out of the computer and have a thorough examination for possible burns. There's no obvious debres or foreign objects left on the motherboard or in the computer - nor floating wires to complicate the physical process' of the computer. The dust collection is at a minimum - not enough to cause cpu or systematical overheat. The motherboard is fully integrated in terms of video graphics, sound, and ethernet. It's designer is Foxconn - the design appears efficient and lower-end. When taking a computer from one power source to another (from one house to another) complications can arise. Power failure can happen - I've seen it happen before. I hope it's not the water that killed the system.
  • depleteduran May 31, 2009
    Thanks for the solution. I checked with an alternative power supply and have had no headway. It might be about time to discover options in terms of warranty...or whole motherboard replacement....thanks again - David
    Brigadier General:
  • 10,406 Answers
That should be your next step. Just connect the "temporary" power-supply to the motherboard and the fan on top of the CPU.
Don't connect to the floppy-drive, the CD-drive, the disk-drive.
If you remove all the RAM, and start it, does it "beep" (to complain about the lack of RAM) ???? If not, then the motherboard (or the power-supply) is the problem.
Posted on May 31, 2009
5 Suggested Answers
SOURCE: Graphics Card Upgrade for HP Pavillion a6600f
if your video slot is a agp try buy a nvidia geforce 7800gs used on ebay cheap and good ;p if u have a pci-x slot u can have a better card also check your power suppy if is enough for it you can ask to a reseller near you cya
Posted on Jun 03, 2009
markzbylut
  • 64 Answers
SOURCE: HP A6600f desktop, loud beep 18 secs off 10 sec, cylce repeats
The beep is a code to tell you what is wrong. POST - Power on Self Test. http://en.wikipedia.org/wiki/Power-on_self-test You can serach the web for more detail as well. Usually memory has popped loose or a connection is not seated fully.
Posted on Apr 26, 2010
indus3
  • 212 Answers
SOURCE: at start up my monitor
the most likely issue is the computer's graphics card. to avoid extra problems, try replacing it with the same model graphics card.
Posted on Sep 27, 2010
joeguest2
  • 2080 Answers
SOURCE: my hp pavillon a6600f make
Shut down and unplug your computer.
Unscrew the two screws on the back of the case and open the side panel of the case.
Remove your RAM memory stick(s) from their holders.
Replace them into their respective holders again.
Ensure they are seated properly and clipped in.
Plug your power cord back in and see if your computer will boot. You can leave the side panel off just don't stick your fingers in there when it's plugged in.
If the problem persists, then you may have one or more bad RAM memory sticks.
If you have more than one stick installed, try removing one and reboot.
Always unplug your PC before removing RAM sticks and try not to touch the copper contacts on the RAM stick to avoid static damage, they can be delicate.
Good luck and please post back about how you make out.
Posted on Jan 24, 2011
Replace power supply
Are you sure the power pack has failed? That should be straightforward and fairly cheap. Note carefully the model and type on the present one, then shop around.
  • Power Supply
    Internal 220W (100V-240V)
    Form factor: Internal for slim form factor
  • Total wattage: 220W
  • Nominal input voltage range:
    • 100-127V/6A (50-60Hz)
    • 200-240V/3A (50-60Hz)
  • Dimensions: 200mm x 85mm x 53mm (7.9 x 3.3 x 2.1 inches)
  • This power supply has an LED to indicate a possible failure condition when the LED is off and power is connected.
Feb 20, 2014 | HP Pavilion Slimline s5710f Desktop PC
HP pavilion will not power up
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 13, 2012 | HP Pavilion a710n (PJ508AA) PC Desktop
My "hp pavilion a220n" won't
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
I am troubleshooting a Pavillion Slimline s3100n desktop pc, approximately 2 years old. It will not power on. When pressing the power button or plugging in the PC, the power switch illuminates, the fan...
It sounds as if your processor is on its way out of your Hard Drive is buggered. try another HD and if this works then its the HD. If it doesnt its your processor in which case you may aswell buy a new computer
May 20, 2010 | HP Hewlett Packard Pavilion Slimline...
My pc won't boot..I get very long beep, pause long
Try resetting the motherboard, by either removing the battery or changing jumpers on the motherboard. If this doesn't work, then motherboard is going bad.
Feb 19, 2010 | HP Pavilion a6600f Desktop PC
If the power goes out on my system the light on the power supply starts flashing and the computer won't start up. have to unplug the power supply from the motherboard and plug it back in to get the...
HP has a page specifically for troubleshooting issues of the power supply unit (PSU) LED indicator below:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&docname=bph06788&product=12455&dlc=en
Sep 22, 2009 | HP Pavilion a735w (PL308AAR) PC Desktop
I hibernated my hp laptop and it refuse to come on again
Normall hibernation can resume from a selection of key / mouse touches.
Some of the HP's resume from the power button even though it is lit.
Sep 05, 2009 | HP Pavilion dv6000z Notebook
Failure to boot Lenovo J3000.
check 1st a ATX power supply if this a good 2nd remove the memory then make a clean using a paper eraser clean all the pin connectors of memory....
May 23, 2009 | Lenovo 3000 J Series 1.80G VBE PC Desktop
HP Pavilion a6600f Desktop PC Logo
604 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
