Disk drive broken on my Advent 9912 computer,bought a HP PhotosmartC4485 A,I,O Due to the faulty disk drive I can not make computer and printer compatible. I logged onto your site yesterday leaving my bank details.Im not sure how I stand with your site?
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    If your computer has a USB port and if you have access to another computer, perhaps you could copy the installation CD to a thumbdrive for installing the printer?
    Brigadier General:
  • 10,406 Answers
Get a second estimate for the repair -- the first estimate was quite expensive. WIthout a working computer, you cannot use the printer.
Posted on May 31, 2009
HP Pavilion a310n faulty hard disk
Thats odd if you cant load linux i would be buying something new whether you go for a new computer or hard drive depends on your financial situation personally would go for new computer nothing feels better than a new computer
Jan 21, 2013 | HP Pavilion a310n PC Desktop
Boot failure error pxe-61 media test failure check cable pxe-m0f exiting pxe rom what shd i do now
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 28, 2011 | Advent Netbook
My computer stopped working some time ago, and I was pretty much certain my hard disk had died (SATA), so I bought a new Hard drive (SATA) and booted my computer....the bios didn't detect the hard drive,...
ONE BAD LEAD?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 18, 2010 | Packard Bell Computers & Internet
Reboot an advent notebook to original settings
the computer shoulda came with a disk and that would be your operating system disk so put it in, then start your computer and if it doesnt boot to the disk, then hit F2 and change the boot options and make it boot from the disk and so when it does boot, then thats when u can reinstall windows back to factory settings but i dunno about advent notebooks. in HP tho, u can do it from the start menu cuz the reinstall settings are already on your computer so ya dont need the disk
Dec 27, 2009 | Advent Netbook
ADVENT DISC DRIVE FAULTY,£203 TO REPAIR. IS IT POSSIBLE TO BY PASS DISC DRIVE TO MAKE PRINTER AND COMPUTER COMPATIBLE? (HP PHOTOSMART C4400 ALL IN ONE ADVENT 9912 COMUTER)
Get another estimate for the repair, since the first estimate is quite expensive. Without a working computer, you cannot use your printer.
May 29, 2009 | Office Equipment & Supplies
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
Advent 9912 wont turn on
remove the ac adapter
take the battery out
be sure nothing is connected with your laptop
then press and hold the power button for 60 secs to drain static as it is the most probable reason laptops stops working.
then connect the ac adapter only and without the battery try powering on the system
if it powers on
you can again shut it down
insert the battery
it should surely power on
Apr 20, 2008 | Dell 2600 Notebook
Advent Laptop 9912
You'll find that at partmaster.
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1651945&query=Advent%209912&model=9912&path=79916,79917,137908:79930
Feb 21, 2008 | Recoton Advent Advent Q2035A 20" TV
k24674
jasbo
jasbo
