Question about Nokia 6030 Cellular Phone
Voice command i tried holding down the right key but the speak now meggage doesnt appear anymore later i checked the place to play the sounds and it said"notallowed"
  • 490 Answers
Chk ur handset settings.chk whether audio message is enabled or not?..orelse try by restoring handset and then reinsert sim....
Posted on Oct 23, 2007
My upper case on the number 2 is not working...I need the * at * sign to send an e-mail to my son...Anything I can do without erasing this..Thanks
try holding down the alt key then type the following with alt still held down on the number pad top the right of the keyboard type 64 then release the alt and @ should appear If this doesnt work first time press number lock numlock key and try again
Mar 07, 2017 | The Computers & Internet
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
Will not load up or take charge
Try removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
If that doesnt work try this:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Mar 01, 2011 | Apple MacBook Air
Mic dont work help i checked the wire and volume and it still doesnt work. ive been using windows media to play the video but there is no sound
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Feb 18, 2010 | Gear Head WC330I Webcam
My mac wont pick up my voice on the microphone on ventrillo. But through itunes it will play the music through vent. What should i do
You just need to let your mac know which hardware you would like to use. Open up System Preferences, and under the Hardware section you will see an item labeled Sound. Open that, and under the input and output sections you will see a list of the hardware.
If this is set correctly, then check your Vent settings. There is usually a key you have to hold down to speak in Vent. Make sure you are using the right one.
Aug 19, 2009 | Apple 24" iMac Desktop
Sound Problem with MAC OS X 10.4.11
This sounds obvious, but the system volume could be down. Go to the System Preferences, and select "Sound". Make sure the output voumne is turned up, and the mute is not on.
If that doesn't work you could try "zapping the pram".
  5. Hold the keys down until the computer restarts and you hear the startup sound again. Continue this until you hear the startup sound four times.
Apr 03, 2009 | Apple Mac OS X 10.4
PS3 plays game wont load XMB
What I did?
1).Shut down the system from the switch on the back.
2).Place and hold your finger down the on/off power button.
3).Turn the switch on the back “ON”, while still holding down the on/off power button.
4).Release your finger from the on/off power button, after you hear 2 beeps.
Apr 02, 2009 | Sony PlayStation® 3 (80GB) Console
Fn option appears in place of letters on keyboard
Sounds like you need the keyboard replaced...
Jan 08, 2009 | Acer TravelMate 2300 Notebook
The ipod won't turn on or do anything?
This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Mar 02, 2008 | Apple iPod nano
Monitor not showing contents anymore.
Try to toggle the monitor screen, hold down the function key and hit the F8 key(usually). Wait a few seconds and try again if it doesnt work.
Dec 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Nokia 6030 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
