How to fix the indicator cause is flushing inside but outside not
No idea offhand to be honest i would need my head under the bonnet to know what wrong .could be anything from the gauze filter in the fuel tank on the bottom of the fuel pump becoming chocked up and leaving the car allows it to drop away to a faulty pump overheating or the contacts ,maybe even a ignition module overheating ,Best advice is ask a local mechanic to have a look for you as normally these early opel corsas with the 4 cylinder engine are bullet proof they are even valve free if the timing belt snaps .
Sounds like you not getting enough fuel. Try replacing you fuel filter which sits under neath the rear near the tank. Just follow the line from the tank and you'll see it or it can be a faulty fuel pump You should get 3 bars pressure from it.
SOURCE: opel corsa ac relay problem
I had the same problem with my Corsa Lite Sport. Try turning the ignition key slightly counter-clockwise when you hear the clicking.
SOURCE: how do i get air bubbles out of my water on a opel corsa 2007 utility pls help
if there are air bubbles while the engine is running it means your head gasket is blown.
SOURCE: where does the chechis no.in opel corsa 2003 model..??
it can be found in the engine compartment passenger side is a riveted plate. the number is 17 characters long it should look something like this: WOL0SB.........or look next to the front passanger seat on the floor, hidden under a small plastic cover along the door step
