Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
In sink erator leaking at bottom by electrical connection
I have exactly the same problem with my in sink erator Badger5 plus as posted by treborzelazn. It started leaking where the electrical connection is at the bottom. How to fix? Can it be repaired? Thanks
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
Posted on Jun 03, 2009
I dismantled my Badger 5 InSinkerator because it was leaking water out of the bottom. From what I can see, there is a foam water seal gasket that seems to have eroded away. I need to find a replacement gasket...
Posted on Dec 30, 2011
We had a Waste King in our old house, it stopped working and they sent us a brand new one. We were not even the original purchasers of the unit and it looked old. In our new home there is an Insinkerator that looks like it is pretty old, it is leaking. I am buying a Waste King L-1001 Legend Series 1/2 HP Continuous Feed Operation Waste Disposer to replace it. I have just had better luck with them...
Posted on Nov 19, 2009
Can my Garbage disposal be fixed
Where exactly is it leaking? Is it leaking out of the bottom of the unit?
Jul 18, 2014 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Badger .5 1/2 in sink erator garbsge disposal leaks from bottom
Replace disposal, motor and electrical connections are getting wet
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 03, 2014 | Garbage Disposals
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My sink erator badger 5 is leaking at the bottom, should I replace it or try and stop the the leaking.
mine was leaking from bottom, dripping off power cord...pulled it apart..the pan that separates the water and food from the electric motor was developing pin holes from corrosion...I dont know that you can get this part...was thinking about tacking a small weld...but best off getting a new one...I am sure it has served...
Jan 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator badger5 is leaking from the bottom
If the seals dry out the disposal will leak. This is caused usually from non-use of the sink as if the disposal sits dry for an extended period of time without water going through the disposal. You can buy new seals and rebuild it, however the time and parts don't warrant unless you want to do it yourself. if it is more than 2 years old or you do not know how old it is you are better off replacing the device.
Jun 25, 2009 | Home
Leaking IN-SINK-ERATOR
Just to let you know that questions are answered by other people who use the site and sometimes are experts in the field that you post in, such as myself. We don't work for Fixya in anyway and the questions are answered by people in their spare time. If your question was not answered it was because there wasn't anyone that knew the answer and plus there are hundreds of questions posted each day. I try to answer a few every day but I can't by any means answer every question. Some never get answered. But anyway, if your garbage disposal is leaking from the bottom, its time to replace it. If its leaking around the neck, then it needs to be removed and reseated with plumbers putty or the neck completely replaced. I hope I have answered your concerns. Have a very nice evening.
Apr 03, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
3,445 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
