Question about Sony Vaio VGN-FZ21ECEK Notebook
Wireless Lan Problem
The Wireless Lan switch is on but it is not activated in the computer. The control panel still indicates that it isn't on. Enabling it from the device manager isn't helping
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
How do i turn the wifi on on my lenovo ideacentre b3?
Step 1:
Feb 24, 2013 | Computers & Internet
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
What are the numbers on my netgear n600 dual band gigabit router?
The numbers are the LAN ports on the router. When a number is turned on, it indicates a LAN device (computer) is connected to the router and is active.
If a device is connected to the router and that LAN port number is not turned on then either the LAN cable is faulty or the LAN card in that computer is faulty or LAN driver is not installed.
May 27, 2012 | NetGear N600 Wireless Dual Band Gigabit...
Were do i turn on my wireless connection on my laptop?
INSTALLING THE WIRELESS LAN DEVICE DRIVER
Please follow the procedures below for installing the Mini PCI Adapter driver:
Installing Wireless LAN driver for Windows XP
1. Click the Start button and then click Run. The Run dialog box appears.
2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe"
3. Click "OK" to implement the setup program to install this driver.
4. Click "Next" twice to continue the installation.
INSTALLING THE LAN DEVICE DRIVER
• Wireless LAN Access When LED turns on indicates that the wireless LAN module is activated. When LED lights off, it indicates that the function is disabled
MUST BE A SOFTWARE ACTIVATED SWITCH
Jan 21, 2011 | Everex StepNote NC1500 Notebook
I can't turn on my wireless LAN. There is a button at the top of the keyboard of my Acer Aspire 4520 but when I press it, it says "wireless LAN disabled". I have tried everything to turn it back on....
Try to restore your PC to the backdated point in SYSTEM RESTORE menu in control panel. Then try to switch ON wireless again. If this step does'nt work it means your Hardware (wireless adapter) is malfunction. Replace with a new one (USB Wireless adapter)
Jan 10, 2018 | Acer Aspire 4520-5582 Notebook
I?m unable to detect any wireless networks, because the WLAN adaptor hasn?t yet been activated. There is a specific ?hotkey? (function+F1) to enable the WLAN adaptor but the keyboard doesn't work anymore...
Hello shge2dope,
The wireless lan can be activated (enabled) from the control panel as follows:
•Click Start (lower left-hand of screen)
•Select Control Panel
•Select Network and sharing Center (might be called just 'Network')
•Select the wireless lan adapter and enable it
* Another way might be to select the WLAN icon in the lower right-hand corner of the screen. Then right-click and select the option to enable it
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Medion MD-40954 Notebook
HP Pavilion dv4000 computer, wireless button disabled
Go to the control panel, hardware, device manager. Uninstall the wireless adapter then restart the laptop.
You can also download the HP wireless assistant:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-33346-1&cc=us&lc=en&dlc=en&product=468789
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Computers & Internet
How do you turn on the wireless function on the esprimo v5535?
hai
According to the laptop's quick guide this is how you enable and disable your wireless:
Radio components: Wireless LAN/ Bluetooth/UMTS
The installation of a wireless LAN module not approved by Fujitsu
Siemens Computers GmbH voids the permits issued for this device
(see chapter "Technical data", Page 22).
Depending on the device variant, wireless LAN, Bluetooth and/or UMTS may be integrated in your notebook.
On delivery, WLAN components are switched on, Bluetooth components off.
Switching the radio components on and off
Start the WirelessSelector using the key combination Fn + F1 .
The WirelessSelector enables you to switch the radio components activated in
BIOS Setup on and off individually.
BUWlMuireTtlSeososthLAN
Press the key combination Fn + F1 to start the WirelessSelector.
The radio component indicator will be illuminated when one or more
radio components is switched on.
If you switch off the radio components, the Bluetooth module, UMTS and wireless LAN transmission unit (antenna) will also be switched off.
You can enable or disable the radio components individually.
BIOS Setup allows you to specify which radio components can be switched on
and off using the key combination Fn + F1 .
Only those components that have been activated in BIOS Setup can be switched on and off using the key combination Fn + F1 .
Conversely, components that are deactivated in BIOS setup cannot be controlled using the key combination.
You can also activate and deactivate the radio components individually in the BIOS Setup. You must have assigned the supervisor password in order for this function to be available.
Pay attention to the additional safety notes for devices with radio
components provided in the "Safety" manual.
Details on using Wireless LAN can be found in the online help system
included in the Wireless LAN software.
You can find more information on how to use Bluetooth on the CD you
received with your Bluetooth software.
Sep 06, 2008 | Siemens Computers & Internet
Sony Vaio VGN-FZ21ECEK Notebook Logo
117 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
