Question about Ruud UBHC Air Conditioner
RUUD Central Air/Heat Pump
My heat pump will not come on in HEAT or A/C. I thought I might have a simple defrost control board problem, but still no go after replacing the board and the defrost relay. I checked the pressure switch and it is not tripped. I've checked all the circuit breakers and they, too, are all set. I've checked the outside unit using the "test" switch inside on the start relay and the unit will come on, but won't stay running on it's own. When I select HEAT, I wait the necessary five minutes for the unit to switch and it keeps switching to AUX HEAT. In A/C the unit does nothing. Can someone provide me with some guidance, here? achiever 10 outside unit has a relay problem and i need to now the proper wiring diagram because i think the " proffessional" wired the new relay improperly. please help
  • First Service May 11, 2010
    can you give us the model # and when was the relay wired in
  • steve
    steve May 11, 2010
    If you are getting low voltage power to the contactor and the contactor does not engage,replace the contactor.
If it runs with the test button it's not getting a call from the stat.
check for 24 v. from common (brown) to yellow. that should give you cooling add 24 v. from common to 'B' ( blue) for heat
Posted on Oct 25, 2009
    Problem Solver:
  • 14 Answers
You may have lost your refrigerant and the unit is shut off on low pressure.
You can check the unit's charge by turning on the indoor fan and pushing the ourtdoor contactor down(the relay with heavy wires going in). With the unit runnig for a couple minuits does the large copper line coming into the outdoor unit from the indoor coil get cold to the touch?
If not you have lost your refrigerant
Posted on Jul 27, 2009
Why Thermostatic Expansion Valves for Wether King 10PJH1801 is not working
it may not be the expansion valve. when they fail it usually loses charge in the bulb capillary. lack of heat should be reversing valve or control issue
Aug 25, 2014 | Ruud Rheem Weather King Heat Pump Defrost...
When should you use emergency heat with a heat pump
when outside temperture gets to low for heat pump to work effiencely
Jan 07, 2014 | Ruud Central System Air Conditioner
Need order of wire color for heat pump
Control Panel R-Red to R at Thermostat
Jan 26, 2010 | Ruud UBHC Air Conditioner
My heat pump will not come on in HEAT or A/C. I thought I might have a simple defrost control board problem, but still no go after replacing the board and the defrost relay. I checked the pressure switch...
Hi; Need more info. How old is the equipment,look on the outside unit data plate it will give the built date usually in the top right corner. Also heat pumps can run with a faulty defrost board. I would check for control voltage at the secondary side of the transformer should be atleast 24 volts ac. Also the test post on the defrost board are for troubleshooting a defrost problem not an operational problem.When the posts are temporarely shorted the condensor will go into a defrost cycle This step will let the tech. know if defrost is operating normally. Also I have seen a reset switch manualy reset but not reinergize the control voltage. Also the outdoor unit has a delay timer that will wait for freon press. to equalize befor letting the unit operate. One more thing do You now if Your tstat is operating normally. One more idea is the defrost sensor if faulty it can leave the condensor in a defrost state of operation. This intern will sometimes go to heat strips because they are used in the defrost cycle to warm up the air conditioning going on durring a defrost cycle. One more thought is does the control contactor have 24 to 27 volts going to it if so replace the contactor. To test this using a voltage meter and touch after waiting 5 min. both sides of the coil. Remember voltage is deadly so ..When in doubt call a qualified tech.I ASSUME NO LIABILITY FOR INJURIES TO YOU OR THE EQUIPMENT BE CAREFULL!!! IF YOU GROUND YOURSELF BETWEEN 230VOLTS THIS BE VERY BAD...alpharome416
Jan 23, 2010 | Ruud UBHC Air Conditioner
Heat not blowing on heat cycle
Have to know what kind of heat it is, Gas, Electric or Electric Heat Pump.
Heat pumps, when air over air type, have an extra setting on the thermostat labeled Emergency Heat, Although these thermostats can work on the other types of heating as well.
Both modern Gas and electric furnaces have the blower controlled by a blower board. The flame and or heating elements can also be controlled by the same or a separate board. SO you could have a board problem, or a safety switch or other symptom causing a safety switch to trip off on you.
Consult with your diagram and find something you can recognize then trace the wires down and follow to where you get the power to turn on the heat (usually always R feeds thermostat and W feeds Heat). Colors of the attached wires means nothing at this point. Look for the terminal designations not colors.
Hope this helps you. Please grade me accordingly and GOOD LUCK. :)
Mar 03, 2009 | Ruud Central System Air Conditioner
Start with the simplest first it,s not fun but it's necessary EVERY TIME. Clean your evaporator and condenser coil, change your air filter. Getting to the evap. coil is often a real headache and a result doesn't get done often. When its clogged as you probably know the refrigerant can't absorb heat at the coil so it tries to absorb heat on the way to the compressor freezing the hot gas line the safety circuits that protect the heat pump compressor from getting liquid refrigerant back to the compressor almost immediately will take the compressor of line (looking somewhat like a defrost cycle). I hope this helps it's a tough repair GL!
Apr 10, 2007 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
566 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
