Front load model mhwe251yg00, washers b-4 spin shows code e1-f6 does not spin
Serial communication error you have two computers one up top the CCU and one down below the MCU it's saying the two are not talking to each other the tech sheet has you go thru about 20 steps to basically come to the same conclusion it's either one or the other which I could help more but I run into the same problem in the field. Most times it's a failed CCU
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
SOURCE: My Frigidaire front load washer
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
I have a Maytag Maxima frontload washer that was getting these two error codes. I found in my case it was due to the tub not draining water as quickly expected. On my model there were two screws at the bottom of the front panel (one on each side towards the floor) Once these screws were removed and my husband tilted the washer up I was able to get my hand behind the panel and unscrew the filter cap that is located towards the middle at the bottom. It is a large plastic circle that you unscrew. With your hand remove any gunk or objects blocking the filter (usually filled with gunk) screw the filter cap back in, screw the front panel screws in and try to run another load. I have had to do this twice so far. You would think if the filter needs to be cleaned out every year or so they would make it more easily accessible.
