I've got a LG 20LS3 LCD-TV but I've lost the power supply.
I know that the original was a 16V 3.2A LIEN CHANG LCA02.
Where can I get a replacement?
I live in Sweden, which means that I have 220V AC.
I would also like to know the name of the kind of plug they use. It is round, quite similar to a DIN-contact but has only four pins, positioned in a square.
SOURCE: Supplying and replacing a LCD screen
i have spoke in the past to LG service and to buy an LCD screen actually costs more than a new tv.
SOURCE: power supply for lg plasma tv
i have a 60 inch tv i just order the power supply kit i want to install it myself do i have to open the whole back of the tv.
SOURCE: my lg 42pc5d tv remote sensor quit working. I am
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
