Question about RCA DRC277 DVD Player
RCA DRC277-A, No sound when played through a Samsung HDTV using the HDMI chord. Chord and TV seem to check out fine. Tried all buttons and menus I could find. Have set sound to PCM, etc.
    Problem Solver:
  • 4 Answers
This particular DVD player has different HDMI audio settings on the menu. There is a setting for Auto, PCM, and None (I think). By default it should be set to Auto which should work for most people. But if you have a finicky receiver or TV set, you might want to manually select PCM.
Posted on Jun 30, 2009
    Problem Solver:
  • 7 Answers
There might be a setting in your tv's audio menu to enable your audio source, which is now hdmi (vs. the rca-type red and white audio cables). Once you select the type of audio you are using, the audio, you should hopefully be able to get sound from your dvd player now.
Posted on Jun 13, 2009
What are all the left side controls on an Elegance JC-618 electronic keyboard
Single and Finger,is chords mode.
In Single,by press one key (eg:A) then chords A is heard,and so on.
In Finger,you must press 3 keys.Example: G-B-D,then you heard G chord. D-F#-A is D chord.
In Finger,lets say you press A chord and want to change to C chord by press one key C only,there's nothing change untill you press C-E-G.
Low, is for chords octave low.
Chords Off,no chords can be play,it mean overall full piano mode..
Single,Finger,Low, can be activate with Sync Start button.
Aug 17, 2015 | Music
What do I need to hook a HDTV up to an Onkyo TX-DS747 receiver
okay hello, you dont need a HDMI cable as it appears your receiver isnt equiped with that feature.The way you have to do this is if you have a source you run the video chord (yellow chord) then then left and right audio (red and white cable) run them from your souce such as satelite or dvd player or game console.you plug them into your input on your receiver then you run one video chord on the output port on your receiver this will put the sound through your receiver and put just the video to your tv.if your tv has a option to run audio out then you just reverse this pretty much.You run auudio left and right from the audio output on your tv to the input on your receiver.then on your menu on your tv make sure you go to speakers and set them to off and set it to output audio if this option is presented.
Mar 20, 2013 | Onkyo TX-DS747
Connect pc to hdtv
depending on your tv and laptop, you will need the appropriate chord to connect to your tv. hdmi or vgi chord.
Dec 17, 2012 | Computers & Internet
No sound on my DVD. Using S connector or jacks. Swapped DVD player, checked the cable connections, went through the menus on both the player and the TV. Never was a problem before.
hi,
if you are connected the S video output of ur dvd to ur tvs s video input , the u should connect another two RCA cable fo audio.S video connection is only for video input. connect the audio out put of ur dvd to the corresponding S video audio input, using a stereo RCA chord.
ok.
Dec 21, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My ps3 stopped working and i use an HDMI chord, i tried holding down the button for 10 seconds then turning it on and still nothing shows up. I checked the chord and it works. Should i plug in the red,...
I think you may be holding the power button down for too long. Instead of holding it down for 10 seconds only hold it down until you hear a second beep (it will beep once as soon as you press it). The console should stay on after the second beep and the display should initialise.
Try this method with both HDMI and AV lead (red white and yellow lead)
I hope this helps and thank you for using FixYa
Sep 02, 2010 | Sony Playstation 3 (PS3) Console
No power
It needs a new Power Supply.
Sep 05, 2009 | Vizio L32 32 in. LCD HDTV
So i have had a ps3 for about 2 years now and the hdmi chord worked fine for 1 year and then all of a sudden i started lossing signal from the tv. If i wiggle the hdmi chord the picture will sometimes come...
Hi friend, see since your regular (component/composite) chord worked well so the problem is with your HDMI chord. It is losing connection with some internal wire try to use another HDMI cable if it still not works so problem may be with your HDMI port.
Composite/component cable works fine but the cost of graphics..... but still HDMI graphics are just too good...
Hope it will work for you.
Jul 09, 2009 | Video Game Consoles & Games
Dvd to amp to tv hookup has little to no connections
It is a lose connection symptom when you wiggling the chord it will be fine it is a cold solder its needs to resolder the connection base so it become firm and works normal again.
Hope it may helps you;
Regards:
VOTIT
Mar 23, 2009 | Yamaha RX-V463 Receiver
Video problems
I would check to see if the AV cord you have is set to HDTV or reg TV if you dont have a HDTV then your setting needs to be on TV.
Trying to use the HDTV will give you this issue where you here sound but no video.
The setting is on the neck where you plug it into the xbox360.
Nov 30, 2007 | Microsoft Xbox 360 Console
Rca hdtv m50wh754s
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA DRC277 DVD Player Logo
317 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
