Question about Saeco Talea Giro Espresso Machine
Alarm light slowly flashing and will not stop
Alarm light is slowly flashing, all components have been checked and are closed, looks like maybe the brew group is not fitting properly?
  • shanliz06 Jun 01, 2009
    I just tried that, cleaned the rails, the N does not look like it is perfectly lined up, just a hair off, but i can't seem to turn it, not sure how to. however the alarm light is still flashing, any other suggestions?
    i will try that, i did forget to mention that after i cleaned the rails and refitted the bean strength light was illuminated.
    President:
  • 1,618 Answers
Try this remove the drain tray,dregs tray and brew unit. Clean the rails that the brew unit slides on, check the gear next to the handle of unit to make sure arrow is on the N. Then re-insert unit and trays.
Posted on May 31, 2009
  • Ernest R
    Ernest R Jun 01, 2009
    The only other thing that would keep the alarm light on is the drain tray and the dregs tray?
Hazard lights flashing and alarm sounding. How do I stop these?
Every car brand and model has its procedure to stop the flashing light and alarm sounding.
But still the common procedure is Make sure boot and bonnet are closed properly.
It can also be a switch, but check your alarm by locking yourself inside the car, and then press the close button on the key 2 times repeatedly until the lock control on the door doesn't make anything. Then open the door by pushing the lever or open the hood . If the horn sounds and the lights blink your alarm is ok , if only the lights blink you should take it to dealer. You can stop the hazard lights and horn sound by pressing the unlock button on the key.
May 12, 2016 | Cars & Trucks
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
Security light stays on (constant) while truck is in use, no obvious problems though. What is going on
when you lock your vehicle with the remote it engages the alarm and the red light will flash fast for about 15 seconds. Then it will start flashing very slowly to show the system is armed. To disarm it you need to open the door with the remote or put the fob in the ignition. If you use the key to open the door and alarm is on it will go off. Only way I know of to make it quit honking and flashing lights is to hit unlock button or insert for into ignition.
I would sit in the vehicle and arm the lock with the remote and watch to light for about 1 minute to see if it does flash fast first then slowly. If it does it is working fine. If it doesn't then take it in and have dealer look at it.
Dec 07, 2015 | 2010 Dodge Ram Pickup 1500
My 1994 grand cherokee trouble screen flashes constantly diplays time date hood open light and rear brake lights help
lets do some...
1: battery reads, 12.6vdc reseted in park,? and 13.3 to 15v running?
yes/no.
2: enigne starts and runs perfect and drives ok?
3: head lights work> right?
check fuses yet.
if above is ok.
then the hood switch is broken, its just a switch telling alarm its closed. ..
rear brake lights.
are the rear brake lights dead, if you look at rear and person 2 steps on brake, key on?
maybe its telling you the truth.
not sure what time date means....
May 30, 2015 | 1994 Jeep Grand Cherokee
Power lock remote control is not working to open and close the doors while burglar alarm light (armed) keeps on flashing. When any door is opened, sound keeps "on" to indicate problem. The...
Check under the hood. Often, there is a small switch that needs to be closed when the hood is shut. This switch sometimes comes loose and when the hood is closed the button is never pushed. Find the magic button and reattach it to it's mount so that the hood will press it when the hood is closed and that should solve the problem. This button works with the alarm system.
May 25, 2011 | 2001 Honda Accord
I have a red light and nothing is working no cofee and no milk nothing
I have a Saeco Easy. Maybe the solution for my machine will help you. You did not specify which light is red I will assume it is the "Alarm" light.
Alarm light (looks like an "!" exclamation point)
• permanently on: signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full.
• slowly flashing: signals that the brew group is not inserted, the dregdrawer
is not inserted, the coffee bean hopper lid is not on, the service door is open
or the steam/hot water knob is not correctly turned to the desired position.
• quickly flashing: signals the need to prime the water circuit
Apr 19, 2011 | Saeco Talea Giro Espresso Machine
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Security alarm stays on and vehicle wont start
Sure the door lock is bad maybe. with the fuses in and the doors clsed try the other locks some jeeps only reset with the hatch lock as all the others are worn out or don't detect tha t the door is closed
Dec 05, 2009 | 1993 Jeep Grand Cherokee
Our machine has stopped working....the alarm light is on and flashing slowly so we have gone thru all the steps in the book to find out what is wrong. When we turn the machine on, the green lite goes on...
If red light slowly flashing....Please check brewunit,dregdraw, door and coffeebean lid is properly in .
If flashing fast..means ventilate(prime the machine)
If itis steady..no water in the tank or time to empty the drip tray.or the more serious case the grinder is not working or not self testing.
Nov 17, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Talea Giro Espresso Machine Logo
607 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
