Toro lawn mower model no. 20041 will start only when starter fluid is sprayed,but will not keep running
Cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
Im not good with toro products but i believe that whatever mechanism pumps fuel into cylinder has failed. you would have to keep priming it to keep it running, basically. that's all i know about toro but having the carb replaced should do the trick and if not the the engine is shot.
