Question about Sony FD Trinitron WEGA KV-30HS510 30" TV
Audio intermittent and popping - Sony FD Trinitron WEGA KV-30HS510 30" TV
  • jerseycitybe May 31, 2009
    I am a former service technician, currently employed in the broadcast industry as a transmitter engineer. I am able to determine that the DC voltages applied to the amp IC are correct, and there is no DC offset at the speaker terminals. I'm hoping that someone has experienced this problem with this set previously and can provide a "quick fix" tip.
  • 10,594 Answers
Audio intermittent and popping is due to Mute signal / command that activates from system control and reason could be dry solder joints in audio amp section and CN2002 pin-5 (SP mute) and pin-8 (A mute)
Please check Q513, 515, 516, 517, 518 & 519, these are mute transistors
Thanks.
Posted on May 31, 2009
    Brigadier General:
  • 3,917 Answers
A loud pop in the speakers is one of two things. 1. DC voltage from the amp instead of the normal AC.(If this is the case the amp is slowly burning the voice coils of the speakers.) 2. a large spike to the input of the amp. (This would be less common, but possible.) The problem is probably in the amp itself. The speakers will get spoilt if not taken care.
Thanks
Makes loud popping noise volume knob seems to be bad
Volume controls are known to go intermittent and cause this.Its a surface mount type and would require exact part.Try removing back of pot to get inside to chemical spray it out with pot cleaner.
May 10, 2014 | Polk Audio PSW111 Speaker
Popping and cracking noise from rt side speaker
You probably have a bad solder connection or an intermittent part failure in the right audio amplifier or its source circuitry. Put in a call for warranty service.
Dec 08, 2009 | RCA Televison & Video
Makes an loud clicking/popping sound
The audio outputs are intermittently shorting to their supply and allowing DC voltage to pass - the speakers will be damaged if it continues. you can confirm this by measuring (with a dc voltmeter)at the speaker outputs for DC volts.
Sep 19, 2009 | Sony STR-DA50ES Receiver
I have a 3 yr old Panasonic 42" Plasma
it might be coming from the actual audio/video source. try hooking up a dvd player or gaming system and see if it still does it.
Jul 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Westinghouse lcd 26 inch
I found that with my Westinghouse SK26H240S lcd tv. that when you turn down the blacklight feature you get a hum thru the audio. so I just turned the blacklight feature to the max and the problem went away, no more audio hum.
Sep 11, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Popping sounds from tv
You are getting a spike through the audio circuit for some reason.. Does the screen stay 100% Normal when it happens? And is it a steady timed thing or intermittent?
Dec 10, 2007 | Sanyo DP32746 32 in. LCD Television
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Sony KVTS27 audio noise and pops
your problem is a stand-up printed curcuit pcb it has several mof those small surface mounted caps that always goes bad and the # on the part is SBX1981or SBX1981-51p its part # is 874213400 its about 11 to 15 bucks . Dont try to repair the part as the pcb is eaten up from the caps leaking all over it. Good Luck
May 06, 2006 | Sony KV-27S42 27" TV
Sony FD Trinitron WEGA KV-30HS510 30" TV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
