Question about Panasonic DMR-ES10 DVD Recorder
How do I block the sensor on ONE of my two identical DVD recorders...?
How do I block the sensor on ONE of my two identical DVD recorders?
I've got two identical Panasonic DVD recorders hooked up to my TV.  How can I block the sensor on ONE of  them when I use my remote?   Is there a material (rubber, metal) that I can place over the DVD's sensor area?  I've experimented with no luck.
Thanks
ej_vianney@yahoo.com
  • edarem Oct 23, 2007
    I don't understand the word, "inibe."
I don't know about ES-10, but in my ES-15 there are 3 numbers code for remote. I think if you change it in one, is possible inibe the remote control response.
Posted on Oct 23, 2007
Samsung DVD-R4000 not recognizing DVD-R discs
As a last resort you can try a firmware update if there is one but don't hold your breath. Unit may simply have lost ability to record and not be able to playback. Not uncommon - happens.
Sep 14, 2017 | Samsung DVD-R4000 DVD Recorder
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
Panasonic DMR-ES30V DVD / VCR Combo Recorder - where can I buy another? If I have to buy latest model, will it finalise DVD's made on the above model?
You may be able to find an identical model for this combo unit on eBay or similar, otherwise if you do end up purchasing a new unit (for example a DMR-EZ48V which is a Panasonic) - you cannot finalise discs recorded on one model in a different one, and I doubt you would be able to even on an identical model, since there would be variations in their digital control circuitry.
This is why recorded DVDs must be finalised in the drive they were written in to enable compatible playback in standard players. You cannot change recording models or drives prior to finalising.
Apr 09, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Can another Insignia DVD Recorder be used to finalize DVD's recorded on another Insignia DVD Recorder?
Unless the Insignia recorders are both IDENTICAL models, same year of manufacture, and have the exact same firmware versions, you CANNOT finalise a disc in one unit that was recorded on another.
Mar 06, 2011 | Insignia IS-DVD040924 DVD Player/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Remote doesn't work for DVD Recorder
It is now working. The DVD is below a Panasonic TV. We blocked the tv remote sensor and the DVD remote started working. We have unblocked the tv sensor and the dvd remote is still working. I'm not sure what was wrong or how exactly we fixed it.
Jan 28, 2009 | Televison & Video
Panasonic DMR-ES10 DVD Recorder Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
