Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Sony KP53S25 rear projection TV - Horizontal lines on display
My Sony KP53S25 53" rear projection TV (standard def) suddenly developed horizontal lines all through the display.
A Google search found some mention of a similar problem being the part "IC301 CXA1477AS Jungle IC 8-752-063-50 on the M board".
Is this accurate, how do I identify the IC & board, and where would I obtain this part?
    Guru:
  • 1,894 Answers
Try this link
see this link and try to understand the blink codes.
this will surely help you
Posted on May 31, 2009
My Sony KP-53HS30 rear projection tv has horizontal squiggly lines in the center of the picture.
What is the issue you are trying to adjust? Convergence or width or what? The set has an adjustment menu that is hidden but can be called up with the remote used in a certain way.
Jun 17, 2012 | Sony KP-53HS30 53" Rear Projection...
Sony rear projection 53" screen
Could be convergence settings?
Feb 25, 2011 | Televison & Video
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Dec 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
LInes in the picture
sounds like retrace lines. Need to trouble shoot your video circuit.
Feb 24, 2008 | Sony KP-53S35 53" Rear Projection...
KP-53S65 blury at times
the screen control and the focus control on the flyback transformer need to be turned down a little
Nov 12, 2007 | Sony KP-53S65 53" Rear Projection...
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
730 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
