Question about Ryobi Cultivator
410R RYOBI CULTIVATOR WILL START WHEN PRIMED BUT WILL NOT STAY RUNNIG
410R CULTIVATOR , I CAN PUSH THE PRIMER BULB 2-3 TIMES AND IT WILL START BUT IS HARD TO START HAVING TO CRANK SEVERAL TIMES. WHEN IT DOES START IT WILL ONLY RUN WITH WHAT FUEL I PRIMED AND THEN DIE.
5 Suggested Answers
  • 1632 Answers
SOURCE: unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Posted on Jun 02, 2009
kfishny
  • 5 Answers
SOURCE: There are two hose/line openings in the gas tank
IT SOUNDS LIKE A TWO CYCLE ENGINE TO ME. THE HOSE GOING TO THE PRIMER BULB GOES TO THE HOSE THAT SITS ON THE TOP OF THE TANK AND DOEST GO IN FAR AT ALL AND IS USUALLY THE BACK. THE OTHER HOSE GOES IN THE NID PART OF THE TANK OR THE PART THAT THE GAS IS AT ITS HIGHEST POINT IN THE TANK WHEN THE UNIT IS IN THE POSITION MOST LIKE IT IS WHEN IN USE USUALLY THIS HOSE HAS A SMALL FILTER IN THE TANK. THIS SYSTEM OPERATES ON PRESSURE. WHEN YOU PUMP THAT BULB, IT PRESURIZES THE TANK FORCING GAS UP THROUGH THE OTHER LINE TO THE CARB. IF YOU ARE SYING THERE IS A 3RD HOSE HMMM, THAT PROBABLY GOES TO THE MIDDLE PART OF THE CARB
REGARDS
Posted on Sep 27, 2009
panilling9
  • 284 Answers
SOURCE: Hello, my Ryobi 410r tiller/cultivator needed new
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Posted on Jun 16, 2011
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
Jun 16, 2011 | Ryobi Garden
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Fuel oil mixture ratio for ryobi 410r cultivator
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Jun 23, 2010 | Ryobi Cultivator
Needs new primer
You are searching for part number 181558. It is a snap in primer bulb with a piece of fuel line.
Oct 02, 2009 | Ryobi Cultivator
There are two hose/line openings in the gas tank of my Ryobi 410r cultivator. Where and which do these two lines go to? Which of them goes to the primer bulb? Also, there are two lines to/from the primer...
REGARDS
Jun 30, 2009 | Ryobi Cultivator
Unable to start Ryobi 410r cultivator
Vitally
Jun 02, 2009 | Ryobi Cultivator
Gas shoots out side of carburator when priming?
If it's coming from the primer bulb, replace the bulb. If it's running out the carburator, take iff the air filter and check for obstructions. 2 - 3 pumps is all it should need.
May 17, 2009 | Ryobi Cultivator
Need Replacement Gas Line for Ryobi 410r
They have the parts your looking for at www.lawnmowerpartstore.com
Apr 12, 2009 | Ryobi Cultivator
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi Cultivator Logo
161 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
