Question about HP Pavilion dv6000z Notebook
My HP Pavilion dv6000's sound system is not working. Stuck mute
My HP Pavilion dv6000's sound system is not working anymore. The mute option on the touchpad is stuck. Every diagnostic I've run says the audio is fine. I've tried to do a system restore and now the system restore doesn't work either. My little grandson loves to watch himself on videos on my computer and he's coming tomorrow. Please help. I have exactly the same problem. Which drivers need to be reinstalled??
    Genius:
  • HP Master
  • 1,250 Answers
Go to device manager remove the drivers then reboot your system then install the drivers, then check,
Posted on May 31, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: My HP Pavilion dv6000's sound system is not
This is a common problem, the cable that connects the button board to the system board goes bad. Usually but not always the power button stops working as well and the speakers. Replacement cables can be purchased on eBay or from: www.2fix.net. Its fairly easy to replace the cables.
Posted on Aug 18, 2009
No souds
is the mute button above the keyboard pressed? Are you running windows 7? Does the soundcard show up in your device manager? Also, on windows 7, the volume mixer provides separate channels for applications, rather than devices as in xp. Click the volume icon, open mixer, and check to see if the internet and other applications are muted. I use a DV6000 and this caused me trouble since this computer had a bad GPU that I fixed, which causes the ssound to stop working when it goes bad. The computer ended up being fine, I had simply forgot about the mixer.
If that doesn't work, try re-installing the sound drivers. If that doesn't work, you might have a faulty BGA (nvidia) chip, which will have to be reflown.
Mar 29, 2010 | HP Pavilion dv6000z Notebook
Hp laptop, dv6000 series..volume button gone pink!
Usually when the volume button is pink(orangey) it means that the volume has been muted. Make sure both on the quick play bar right of the power button and in the task bar, that the volume has not been set to mute. Also check the audio drivers and make sure the drivers haven't been corrupt and reinstall or re-download new updated drivers in needed.
Aug 27, 2009 | HP Pavilion dv6000z Notebook
Laptop DVD
Try cleaning the DVD drive with compressed air, if it still does not work try cleaning the drive with a DVD disk cleaner. if it still does not work and the software for the DVD drive has been confirmed as operational then the drive is dead and needs replacement.
Jul 07, 2009 | HP Laptop Keyboard for HP Pavilion DV6000...
My HP Pavilion dv6000's sound system is not working anymore. The mute option on the touchpad is stuck. Every diagnostic I've run says the audio is fine. I've tried to do a system restore and now the...
Its a known problem with this laptop,everything appears to be working , but you get no sound from the speakers though the headphone jack works fine.
If you press down on the casing near to the power button and the sound comes on then you have a loose contact/ribbon cable fault which these laptops are prone to.
As to the "Fix" either use a set of external speakers or take it into a repairer to get it fixed,
If it's still under warranty then you have a claim.
Cheers, adrian.
May 16, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 no sound
Go to start, control panel,
click sounds & or audio.
check your settings are correct in here.
Should be good then.
Regards
Richard.
Apr 28, 2009 | Computers & Internet
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
My HP Pavilion dv6000's sound system is not working anymore. I really do not know exactly what I did. The mute option on the touchpad got stuck and I tried to fix it by going on the sound options. When I...
The easiest way to fix that is : try to do a " system restore" I don't mean restore windows. I mean , revert windows about a day before your sound was working properly. If you have saved anything in your computer between then and now, I recommend you backing up these files. If it does not work, let me know
let me know if you need instructions how to do the steps
best luck
Apr 08, 2009 | HP Pavilion dv6000z Notebook
My sound on my HP dv6000 doesn't work.
There should be a speaker mute switch (or fn key and F key combination). If that does not work, open the volume control and see if you in fact have it muted.
Mar 14, 2009 | HP Pavilion dv6000t Notebook
Logitech Deluxe Webcam for Notebooks turns of sound
Try going into Control Panel, go to Sounds and then click on speakers and make sure it isn't muted or the right speakers are not set as default. If I knew what operating system you were using I could better direct you as to what to do. Hope this is of some help. Bud
Jan 03, 2009 | Logitech Webcam
HP Pavilion dv6000z Notebook Logo
348 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
