Question about ASUS K8V-SE Motherboard (MBASK8VSE)
Asus k8v se data-2 data+2 ground and vcc wires
Where do i connect these and what order
    Scholar:
  • 155 Answers
You can download the manual from this location http://dlsvr01.asus.com/pub/ASUS/mb/sock754/k8v_basic/e1529_k8v.pdf
Go to page 1-21 and see the extra USB connectors. If you are talking about your wires coming out from your case and used for a USB port like the one in the front, you should connect them to any of the 4 available USB channel following the polarity. For example connect your Vcc to USB+5V, groung to GND, data-2 to USB_P8- and data+2 to USB_P8+
Let me know if you need more help
Posted on Oct 23, 2007
2002 Ford Escape 3.0 engine How does the vacum hoses go?
There is no order to connect them. They will only stretch so far and go on certain ports on the plenum.
Jan 18, 2015 | 2002 Ford Escape
I need a spark plug wiring diagram from distributor cap to engine for a 1955 Nash Rambler flat 6-cyl
From this site:
http://www.carnut.com/specs/gen/nash50.html
The best you can do is to take the firing order for your car from the chart and set the timing mark at TDC and connect the wires to match the order. Cylinder one should be the front cylinder on the 6. Connect the wire from the tower the distributor points to to the first cylinder in the listed firing order, Rotate the engine 120 degrees the correct direction and connect the tower there to the second in the firing order. The engine should go a full two turns of the crank to go through the complete firing order.
Apr 05, 2010 | Spark Plugs BR4HS Plug 10/BX #3322
I am in need of the firing order for the spark plug wires for a 1991 pontiac grand prix
For the 2.3L:
Firing Order:
1-3-4-2
Cylinders:
1---2---3---4
(front of vehicle)
For the 3.1L
Firing Order:
1-2-3-4-5-6
Cylinders:
1---3---5
2---4---6
(front of vehicle)
Ignition Connections:
[1-4] [6-3] [2-5]
(front of vehicle)
For the 3.4L:
Firing Order:
1-2-3-4-5-6
Cylinders:
1---3---5
2---4---6
(front of vehicle)
[1-4] [3-6] [2-5]
Feb 13, 2010 | 1991 Pontiac Grand Prix
(1) How do I connect to my internet with my
1.In order for you to connect to the internet through your wireless acer laptop, you should first prepare your laptop to accept wireless connections in order for you to set the proper settings. On you network configuration under the TCP/IP settings where you put the Ip address, you should set it to dynamic because when you connect to another network, the router should give you the ip address in order for you to connect to the internet.
2/ In order for you to charge your acer laptop, you should have a power adapter in which you connect it from your laptop going through a power source. And also you should have the correct Power Configuration in order for you to charge your laptop, you should set the right power schemes as Portable / Laptop.
Jan 20, 2010 | Acer Aspire One PC Notebook
What is the firing order and spark plug connection?
4.0L OHV Firing Order Firing order for the 4.0 liter OHV V6 is
  • 1-4-2-5-3-6
4.0L SOHV Firing Order Firing order for the 4.0 liter SOHV V6 is
  • 1-4-2-5-3-6
5.0L Firing Order Firing order for the 5.0 liter V8 is
  • 1-3-7-2-6-5-4-8
How to Find the Cylinder Order V6 When standing in the front of the vehicle the cylinders are numbered 1-3 up the passenger's side and 4-6 up the driver's side. How to Find the Cylinder Order V8 When standing in the front of the vehicle the cylinders are numbered 1-4 up the passenger's side and 5-8 up the driver's side.
Jul 30, 2009 | 1999 Ford Explorer
Keyboard is stuck and need change boot order
You can try connecting an external keyboard. When the external is connected the BIOS may ignore in built-in keyboard, bypassing your keyboard error.
You can also try removing the stuck key by prying it up GENTLY.
The answer to your question is unless you can get a working keyboard connected to your computer there is no way to change the boot order. Without a working keyboard you can't get into the system setup (BIOS), nor can you press the correct key.
Jan 10, 2009 | HP 418446-001 - HP Special Edition L2000...
Connecting ps3 to cinema system
There is no substitute for HDMI. However, the 'digital in' cable connection that you want to use is still digital and will sound almost exactly the same. The differences are barely noticeable to the human ear. Here is a list for you to see the pecking order of each type of connection.
Audio connections from best to least go in this order:
1. HDMI (digital)
2. Fiber optic (digital)
3. Coax - Digital (digital) <--- The one you want to use.
4. Component (analog)
5. RCA/AV (analog)
Video connections from best to least go in this order:
1. HDMI (full HD digital)
2. Component (Blue, green, red, white, red - HD analog)
3. S-Video
4. RCA/AV (Yellow, white, red)
Good luck!!
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
ASUS K8V-SE Motherboard (MBASK8VSE) Logo
2,040 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
