I have a Kenmore Side-by-Side refrigerator (106.58539700) that has just recently been having problems. Today was the second time that I came home and found that the freezer and fridge were warm. I played with the temperature knobs a little bit and it came back on a short time later, but I'm just waiting for it to stop working again. The lights and everything else still work, but the unit just stops cooling for some reason. I have only had the unit for about a year, and I'm suprised to find this sort of problem at this point. Any advice would be greatly appreciated!
SOURCE: REFRIGERATOR MODEL 106 IS HOT ON THE OUTSIDE.
Make sure the condenser fan underneath near the compressor is running when the compressor runs. How to test it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Testimonial: "Thank you, pulled out refrigerator and fan was not turning and was stiff to manually turn. Now just to remove and replace."
SOURCE: Admiral Refrigerator Model # RTSA154A temperature
Clockwise colder. Order new knob Bi Coastal Appliance Parts 1-800-673-1262
Testimonial: "Thank You bobicehouse! I don't have a manual and could not find one online. thanks again! : )"
SOURCE: freezing of vegetable in refrigerator
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Check out the water running tip...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Is there any way to tell if the problems lies with the thermostat versus the relay on the condenser, or the defrost timer?
