Question about Philips Televison & Video
Personal DVD player does not play
Personal DVD player makes a grinding sound when attempting to play DVDs.
  • rector1 Jun 01, 2009
    Worked like a champ! Thanks for the feedback!
    President:
  • 814 Answers
This unit is having a problem in the laser transport section of the player. The unit needs to be cleaned and cleared of all dust and debris impeding the operation of the laser transport operations. You need to open the compartment the the discs are put in and use a can of compressed air to blow clear all dust and debris from the compartment. Then use cotton swabs to wipe the laser transport clean of dust and debris. be very carful not to touch the laser lense with your hands. Use small amounts of Isopropyl alcohol to loose up any hard dust or dirt on the transport rails and gears. Check to see if the ribbon cable has become entangled with the transport.Make sure the transport operation is smooth and balanced. After doing a thorough cleaning, you can test the players operation by playing a dvd to see if it is working properly. If it is not working properly you can go to the set-up menu of the player and restore its setting to the factory settings. This can be done with the defalult function in the preference section of the set-up menu. Now you can try playing the dvd again.If you are still having problems, you can call Phillips customer support at this telephone number 1-888-744-5477. Give them the model number of your dvd player. Explain to them the problem you are having with the grinding noise of the transport heard when attempting to use the player.They will be able to tell how to get your dvd player serviced and repaired. I hope this information helps you with your problem.
Posted on May 31, 2009
Grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Jun 09, 2012 | Philips Televison & Video
Hi sir iam having a massege on when i play i dvd compac DVD decoder is not instaled while when i ply a sofware dvd it works properly what is it ?
Windows soes not come with the codec to play DVDs. You need to install it. There are many free DVD codecs online, many of them included with other media players. My personal favorite is the k-lite mega codec pack. Do a google search for it and download it and install. It will give you the option of making Media Player Classic your default player(My personal choice) or if you want to continue to use Windows media player you can select that as well.
Aug 18, 2011 | Computers & Internet
Up until yesterday our dvd player was fine, today I put in a dvd and there is no sound. I have put a couple of dvds in and there is no sound except for one dvd I put in this works fine?
the dvds you put in are not compatible to your dvd player.but you can clean the lens and see what it does.good luck.dvds work with region.check the region of your dvd player and dvd you are attempting to play.
Mar 04, 2011 | Televison & Video
Old dvds wont play in old or new player bought 3 brand ones still wont work what brand player shuld i buy tell me whats wrong
If you have purchased multiple dvd players and none of them will play your DVDs (including your old player which previously played the old DVDs), then your issue is with the DVDs. You have to replace them because they have been damaged or scratched and can't be read by the laser anymore. DVDs are not indestructible and can eventually be damaged beyond repair. You'll have to replace the DVDs, which makes more economic sense than buying multiple DVD players to try and play them. If these are home movies or personal recordings you should contact a local computer store about data recovery.
Feb 15, 2011 | RCA Televison & Video
HP dvd play on my laptop malfunctioning
grinding sounds is from the dvd drive itself. Sounds like its not sitting properly in the drive or the holder that it sits in is going bad. Either way replace the drive and that will take care of the grinding sounds. Also the more grinding sounds that happen, the more of a chance you take on your dvds getting scratches on them and going bad eventually.
Jun 11, 2009 | Compaq Presario Notebook
Princess dvd player making grinding noise(Won't play the disk)
It is the problem of the cooling fan in your player .Provide lubrication
Dec 03, 2008 | Disney Princess MCP DVD2050P DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Insignia portable dvd player
It sounds like the player needs to be cleaned. Just go to your local electronics store and get DVD player cleaning disk. They are only like $10 and do the trick. Whatever you do, DONT blow into the player as it will only make it worse.
Dec 31, 2007 | Televison & Video
Televison & Video Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
