Question about Hobart H600 Stand Mixer
Hobart H600 Double Pole Breaker
I had an electrician run wiring for my Hobart H600 mixer. In our old location it had a double pole breaker, and he installed a single pole breaker. When I push the start button it hums until I realease the button the does not turn on. Is it not getting enough power? Do I need the electrician to put in a double pole breaker?
    President:
  • 1,865 Answers
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
Posted on May 31, 2009
  • 20 Answers
Listen to the buffalonyman he knows what he is talking about the most problems we have are electricans
Posted on Jun 11, 2009
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
Type of switch
The start switch should be a single pole momentary switch which engages a latching circuit. When you press the stop button it opens the latching circuit. The latching circuit is usually a relay, but it could be a centrifugal switch on the motor. I can't find a wiring diagram to be able to tell you for certain.
Mar 29, 2014 | Hobart A200 Stand Mixer
Hobart h600t . Makes noise on speed 3 and trips on overload. I checked start cap all electrical components all look normal.
I'm having the same problem cap and all look good but still the motor won't run and the the overload trips the breaker
Jan 13, 2014 | Hobart H600 Stand Mixer
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
Got a hobart mixer model h600-t cutting off and kicking breaker,it runs sometimes for about 5 min. when the ladys are mixing bread,checked amps,not under a load
If you can access the brushes you may want to inspect them. If anything but the carbon brush is touchiing thhe armature. It with trip a breaker.. Unplug it before accessing the brushes < -- my disclaimer :)
Oct 27, 2009 | Hobart H600 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Hobart 600 wiring connection
The ground wire attaches to the ground lug under the top.
Mar 16, 2009 | Hobart H600 Stand Mixer
Hobart D300T Mixer Loud Buzzing and No Spinning
You may have a wire not fully seated in your plug, or the worm gear you've just replaced is bound by something ( a gear tooth?) or wrong worm gear. Check to see if all the gears are seated properly. You should be able to turn the agitator by hand. If not, something is jammed in the gears. The other possibility is the windings in the armature are bad.
Mar 10, 2009 | Hobart D300 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
95 year old hobart mixer: two pole single throw switch
Im a tech for hobart and have seen old mixers but not that old.Hobart wont have parts but you could goto an electrical supply place,take the switch and ask them for something universal.
Dec 16, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart H600 Stand Mixer Logo
326 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
